SMTP Client - Project Showcase - Netduino Forums
SMTP Client
email smtp
No replies to this topic
#1 David Weaver
David Weaver
  • 50 posts
  • LocationBloomington IL
Posted 01 December 2015 - 04:49 PM
Good Morning,
I am working on a project that requires a low temperature alert when the temperature is below 50 degrees. In addition it needs to send the IP address to connect to. The solution is to send an email using GMX mail.  http://www.gmx.com/. Once an email address is created the project below will send the email message to any email address. I am only using GMX for sending the message to a Gmail address. Pavel Bansky inspired parts of the project links to is blog and source code are below.
Sub Main()
        'Set the properties
        smtp.Properties.Host = "mail.gmx.com"
        smtp.Properties.Port = 587
        smtp.Properties.UserName = "YourEmailAddress@gmx.us"
        smtp.Properties.UserPassword = "YourPasswrod"
        smtp.Properties.SenderAddress = "YourEmailAddress@gmx.us"
        smtp.Properties.RecipientAddress = "AnyOne@gmail.com"
        smtp.Properties.Subject = "Netduino sent this message"
        smtp.Properties.Body = "Hello world my IP address is "
        'Send the message
        Dim Response As String = smtp.Send
        If Response <> "250" Then
            Debug.Print(Response)
        Else
            Debug.Print("Success!")
            Debug.Print("My IPaddress is: " & smtp.Properties.IPAddress)
        End If
    End Sub
'Put the code below in a new class object
Imports System
Imports System.Text
Imports System.Net
Imports System.Net.Sockets
Imports System.Collections
Imports Microsoft.SPOT
Imports Microsoft.VisualBasic.Constants
'*****The work around in AUTH PLAIN and other functions were inspired by Pavel Bansky
'*****Dim Data() As Byte = Encoding.UTF8.GetBytes("\0" & Properties.UserName & "\0" & Properties.UserPassword)
'*****SendCommand("AUTH PLAIN " + System.Convert.ToBase64String(Data))
'*****The lines above will not work see the links below
Public Class smtp
    Public Structure Properties
        Public Shared SenderAddress As String
        Public Shared RecipientAddress As String
        Public Shared UserName As String
        Public Shared UserPassword As String
        Public Shared Subject As String
        Public Shared Body As String
        Public Shared Port As Integer = 25
        Public Shared Host As String
        Public Shared IPAddress As String
    End Structure
    Private Shared Socket As Socket
    Public Shared Function Send() As String
        Dim Response As String = String.Empty
        Dim ReturnCode As String = String.Empty
        Try
            Dim hostEntry As IPHostEntry = Dns.GetHostEntry(Properties.Host)
            ' Create socket and connect to the server's IP address and port
            Socket = New Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp)
            'Connect
            Socket.Connect(New IPEndPoint(hostEntry.AddressList(0), Properties.Port))
            'Get the Mail Servers response
            Response = GetResponse()
            ReturnCode = Response.Substring(0, 3)
            If ReturnCode <> "220" Then
                Socket.Close()
                Socket = Nothing
                Return Response
            End If
            Debug.Print("First Response should be 220: " & Response)
            '******Authentication
            SendCommand("EHLO localhost")
            If ReturnCode <> "250" Then
                Socket.Close()
                Socket = Nothing
                Return Response
            End If
            Debug.Print("Authentication Response should be 250: " & Response)
            'Get outside IP address
            If InString(Response, "[") Then
                Dim ipStart As Integer = Response.IndexOf(CChar("[")) + 1
                Dim ipEnd As Integer = Response.IndexOf(CChar("]"))
                Properties.IPAddress = Response.Substring(ipStart, ipEnd - ipStart)
            End If
            'Login
            If InString(Response, "LOGIN") Then
                SendCommand("AUTH LOGIN")
                If ReturnCode <> "334" Then
                    Socket.Close()
                    Socket = Nothing
                    Return Response
                End If
                Debug.Print("Authentication Response AUTH LOGIN should be 334: " & Response)
                Dim data() As Byte = Encoding.UTF8.GetBytes(Properties.UserName)
                SendCommand(System.Convert.ToBase64String(data))
                    Socket.Close()
                    Socket = Nothing
                    Return Response
                End If
                Debug.Print("Authentication Response User Name should be 334: " & Response)
                data = Encoding.UTF8.GetBytes(Properties.UserPassword)
                If ReturnCode <> "235" Then
                    Socket.Close()
                    Socket = Nothing
                    Return Response
                End If
                Debug.Print("Authentication Response for User Password should be 235: " & Response)
            Else
                'Plain
                If InString(Response, "PLAIN") Then
                    Dim userBytes As Byte() = UTF8Encoding.UTF8.GetBytes(Properties.UserName)
                    Dim userLen As Integer = userBytes.Length
                    Dim passBytes As Byte() = UTF8Encoding.UTF8.GetBytes(Properties.UserPassword)
                    Dim login As Byte() = New Byte(userLen + passBytes.Length + 1) {}
                    login(0) = 0
                    login(userLen) = 0
                    Array.Copy(userBytes, 0, login, 1, userLen)
                    Array.Copy(passBytes, 0, login, userLen + 2, passBytes.Length)
                    SendCommand("AUTH PLAIN " + System.Convert.ToBase64String(login))
                        Socket.Close()
                        Socket = Nothing
                        Return Response
                    End If
                    Debug.Print("Authentication Response for AUTH PLAIN should be 235: " & Response)
                End If
            End If
            SendCommand("MAIL From:<" + Properties.SenderAddress + ">")
            Debug.Print("Mail from Response should be 250 " & Response)
            'To
            SendCommand("RCPT To:<" + Properties.RecipientAddress + ">")
            Debug.Print("Mail To Response should be 250 or 251 " & Response)
            'Make the message
            Dim message As String = "Subject: " + Properties.Subject & vbCrLf
            message += "From:<" & Properties.SenderAddress & ">" & vbCrLf
            message += "To:<" & Properties.RecipientAddress & ">" & vbCrLf
            Dim now As DateTime = DateTime.Now
            message += "Date: " + now.ToString("ddd, d MMM yyyy HH:mm:ss " & vbCrLf)
            message += "Content-Type: text/plain;" & vbCrLf & vbTab & "charset=""UTF-8""" & vbCrLf & vbCrLf
            message += Properties.Body & Properties.IPAddress
            'send the message
            SendCommand("DATA") '
            Debug.Print("Response to DATA should be 354 " & Response)
            SendCommand(message & vbCrLf & "." & vbCrLf)
            Debug.Print("Response to send the message should be 250 " & Response)
            Socket.Close()
            Socket = Nothing
        Catch ex As Exception
            Socket.Close()
            Socket = Nothing
            Debug.Print("Error in smtp Send: " & ex.ToString)
            Return "Error in smtp Send: " & ex.ToString
        End Try
        Return ReturnCode
    End Function
    Private Shared Sub SendCommand(command As String)
        If command.LastIndexOf(CChar(vbCrLf)) < 1 Then
            command += vbCrLf
        End If
        Dim buffer As Byte() = Encoding.UTF8.GetBytes(command)
        Socket.Send(buffer)
    End Sub
    Private Shared Function GetResponse() As String
        Dim buffer As Byte() = New Byte(511) {}
        While Socket.Poll(15000000, SelectMode.SelectRead)
            Dim bytesRead As Integer = Socket.Receive(buffer)
            Dim c As Char() = Encoding.UTF8.GetChars(buffer)
            For i As Integer = 0 To c.Length - 1
                Response += c(i)
            Next
            If Response.LastIndexOf(CChar(vbCrLf)) > 1 Then
                Exit While
            End If
        End While
        Return Response
    End Function
    Public Shared Function InString(ByVal String1 As String, ByVal StringToFind As String) As Boolean
        Try
            If String1 = String.Empty Then Return False
            If StringToFind = String.Empty Then Return False
            String1 = String1.ToUpper
            StringToFind = StringToFind.ToUpper
            If String1.IndexOf(StringToFind) = -1 Then
                Return False
            Else
                Return True
            End If
        Catch
            Return False
        End Try
    End Function
End Class
Also tagged with one or more of these keywords: email, smtp
