Minimum Vin Power
#1 icabodcam
icabodcam
  • 8 posts
Posted 10 November 2015 - 02:13 PM
I'm prototyping a power meter for an unattended remote system.  The power system in the device is 24VDC, and I've got some other 12VDC items in there, but I really don't want to put any more drain on the battery system.  So I'm thinking of powering the ND+2 with a LiPo system.  I've been looking at Adafruit's PowerBoost 500 shield as a pretty good plug and go solution, with the exception that if I'm not wrong the Vin pin requires a minimum of 7.5VDC, and the powerboost is providing only 5VDC.   Can someone verify if I can power the ND+2 from Vin with as little as 5V?
---EDIT---
I just remembered that I've experienced this before.  5V won't work, so I'm changing my question.
Has anyone else found a solution for powering from a rechargeable battery?
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 10 November 2015 - 03:16 PM
I think you can power with 5V.
The barrel jack input is a minimum of 7.5V but the 5V header pin can take 5V.  You just need to make sure you get the regulation right.
#3 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 11 November 2015 - 05:17 AM
Hi
I use a solar charger shield (plus a suitably sized battery & optional solar panel) from Seeedstudio as a "UPS" for my Azure IoT FIeld gateway Netduino devices.
http://www.seeedstud...v22-p-2391.html
Regards
@KiwiBryn
blog.devmobile.co.nz
#4 Nevyn
Nevyn
  • 1072 posts
Posted 11 November 2015 - 05:53 PM
That look nifty.
