Best Answer cSharper, 23 July 2015 - 03:09 PM
So I ended up reinstalling the firmware, and SDK's and I no longer get the error!
![]() System.NotSupportedException
Started by cSharper, Jul 21 2015 08:31 PM
netduino plus notsupportedexception two
![]() Best Answer cSharper, 23 July 2015 - 03:09 PM
So I ended up reinstalling the firmware, and SDK's and I no longer get the error! Go to the full post![]()
Posted 21 July 2015 - 08:31 PM Hello all, I'm new to netduino,
Everytime I try and run any program, I get the following error:
An unhandled exception of type 'System.NotSupportedException' occurred in SecretLabs.NETMF.Hardware.Netduino.dll
I've recopied these dll's into my project folder, and even tried to make a new project and still get the same error. I fortunately am able to continue through the error, but I'm curious as to what is causing it and how to fix it.
Thanks!
Posted 21 July 2015 - 09:46 PM
Hi cSharper,
Do you get this exception when you create a simple "add number in a loop and debug.print the value" type of hello world app? Also...what board are you using, which version of firmware, and which version of the SDK? Welcome to the Netduino community! Chris
Posted 23 July 2015 - 12:27 PM Hi Chris, Thank you for getting back to me. Yes I get it when doing any simple hello world program, so I assume it has something to do with my setup. I am using a netduino plus 2 and Visual Studios 2013.
DeviceInfo: HAL build info: 4.3.1.0, Netduino Plus 2 (v4.3.1.0) by Secret Labs LLC OEM Product codes (vendor, model, SKU): 34, 177, 4102 Serial Numbers (module, system): 00000000000000000000000000000000 0000000000000000 Solution Build Info: 4.3.1.0, Netduino Plus 2 (v4.3.1.0) by Secret Labs LLC AppDomains: default, id=1 Assemblies: mscorlib,4.3.1.0 Microsoft.SPOT.Native,4.3.1.0 Microsoft.SPOT.Hardware,4.3.1.0 Microsoft.SPOT.Net,4.3.1.0 System,4.3.1.0 Microsoft.SPOT.Hardware.SerialPort,4.3.1.0 Microsoft.SPOT.IO,4.3.1.0 System.IO,4.3.1.0 Microsoft.SPOT.Hardware.PWM,4.3.1.0 Microsoft.SPOT.Hardware.Usb,4.3.1.0 SecretLabs.NETMF.Diagnostics,4.3.1.0 SecretLabs.NETMF.Hardware.Netduino,4.3.1.0 Microsoft.SPOT.Hardware.OneWire,4.3.1.0 Microsoft.SPOT.Time,4.3.1.0 SecretLabs.NETMF.Hardware,4.3.1.0 MyNetDuino,1.0.0.0 GoBus,1.5.0.0
Posted 23 July 2015 - 03:09 PM Best Answer So I ended up reinstalling the firmware, and SDK's and I no longer get the error! Also tagged with one or more of these keywords: netduino, plus, notsupportedexception, two
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | |||||||||||||||||||||||||||
