Where can I find a list of the issues that must be check to insure Netduino compatibility with Arduino shields?
Thanks!
![]() Shield Compatibility Specs
Started by Bernie, Jul 19 2015 11:44 PM
Posted 19 July 2015 - 11:44 PM Where can I find a list of the issues that must be check to insure Netduino compatibility with Arduino shields?
Thanks!
Posted 20 July 2015 - 12:44 AM
Hello! Why? Do you have one in particular that you are not sure of? Its listed on the first page for this discussion. Its also pinned there. Doctor Who "This signature does not exist!"
Posted 20 July 2015 - 01:13 AM "Why?" Because it would be handy to know as I experiment with Netduinos.
"Do you have one in particular that you are not sure of?" Yes, the Seeed DTMF board. But the point is to learn what to look for so I don't have to ask each and every time I need a board to use on a project.
"Its listed on the first page for this discussion. Its also pinned there." That is a list of compatible boards. Boards that have already been ruled compatible. The first issue is it doesn't list the non compatible, so there is no way to know if the board I'm interested in was tested and doesn't work or just wasn't test. The second issue is that I'm asking what should be verified, tested, or check so that I can contribute to the process rather than just having to suck off everyone else's work.
So the question is what needs to be checked, verified, tested, etc to determine if a board is compatible? Is there a list anywhere of the things to verify?
Posted 21 July 2015 - 11:44 PM
Hi Bernie,
The main things you'll want to verify, for compatibility: 1. Does the accessory work with 3.3V logic signals? 2. Does the accessory require special Arduino drivers? Or does it use basic I2C, SPI, UART logic that can be used from (directly, or via a custom driver) C#? 3. How much current does the accessory require? Netduino has been designed for best-in-class hardware compatibility with Arduino shields. There are even some Arduino shields which work with Netduino but don't work with Arduino's newer Due boards. In the end it's usually a concern of software support (although there are a few cases where the hardware isn't compatible). Chris
Posted 22 July 2015 - 02:24 AM Thanks Chris, I'll report back what I find.
Bernie 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
