SPLIT: Integrated MAC and 10 vs 100 mbps
6 replies to this topic
#1 xc2rx
xc2rx
  • 27 posts
Posted 14 July 2015 - 07:19 AM
Hi Sukasa,
We have looked at making a Netduino 3 Ethernet PoE--but the added cost would put it out of the range of most makers. This is certainly something we could do for commercial customers in volume.
One good alternative I have seen for many maker applications is a PoE splitter.
What are you favorite things about Netduino 3 Wi-Fi?
If you guys do come up with a Netduino 3 with Ethernet, could you not use an EMAC+EPhy chip over SPI with a limitation of just 10Mbps like Netduino Plus 2? Could you guys use either the STM32F407VE or STM32F427VI that comes with a builtin EMAC then add an EPhy using MII/RMII to achieve 100Mbps performance speed? That would be awesome for many of the projects I work on. Let me know what to expect for the Ethernet version if possible.
#2 neslekkim
neslekkim
  • 350 posts
  • LocationOslo, Norway
Posted 14 July 2015 - 07:43 AM
They use the STM32F427 on the Wifi board, that chip have ethernet, but not sure if it is available on the 100pin package?
Asbjrn
#3 Juzzer
Juzzer
  • 135 posts
  • LocationHertfordshire, UK
Posted 14 July 2015 - 07:55 AM
yes it comes in 100 pin which you can hook up to a PHY
#4 Chris Walker
Posted 14 July 2015 - 04:23 PM
Hi xc2rx,
For full-speed 100mbps data transfer, you're probably best off looking at native code solutions (or higher-end PC hardware). NETMF is really targeted towards lower-bandwidth applications, single-chip devices, etc. We used the integrated PHY on Netduino Plus 1...but it offered little real-world application performance benefit over an external MAC+PHY solution. And with an external MAC+PHY solution, makers building custom boards can scale down to a 64-pin lower-resource chip and still affordably hook up Ethernet if/when desired.
We designed Netduino.IP to logically separate out the link layer (MAC portion) from the IP implementation. So if you wanted to create a native code interop driver for an on-chip MAC you can use the rest of the stack as-is.
P.S. Netduino.IP also has built-in driver support for the Asix AX88796C which supports 100mbps speeds for people whose hubs/switches prefer 100mbps devices.
#5 neslekkim
neslekkim
  • 350 posts
Posted 14 July 2015 - 04:44 PM
Chris, If you are splitting threads, inform about that so we don't think you are deleting posts.
Asbjrn
#6 neslekkim
neslekkim
  • 350 posts
Posted 14 July 2015 - 04:46 PM
And btw, there are Ethernet versions of the Netduino3 here: http://www.amazon.co.../dp/B00WAHCKEK/
But still not possible to order from outside US, and the shop that should allow for that is nowhere to be seen.
Asbjrn
#7 xc2rx
xc2rx
  • 27 posts
Posted 14 July 2015 - 06:21 PM
Where can I find information about the Netduino 3 Ethernet board? I don't see it anywhere on the netduino.com website. I want to see the schematic if possible. Thanks!
