Inconsistent Results When Writing to SD Card
Best Answer bgreer5050, 25 June 2015 - 01:38 AM
The solution is to add
VolumeInfo.GetVolumes()[0].FlushAll();
after flushing the stream writer.
using (var filestream = new FileStream(@"SD\Logging\log.txt", FileMode.Append,FileAccess.Write))
StreamWriter streamWriter = new StreamWriter(filestream);
streamWriter.WriteLine(strLog + " - " + DateTime.Now.Ticks.ToString());
streamWriter.Flush();
VolumeInfo.GetVolumes()[0].FlushAll(); // Force write to sd card
1 reply to this topic
#1 bgreer5050
bgreer5050
  • 28 posts
Posted 24 June 2015 - 10:49 PM
I have a static class called Logger with two methods
  1. VerifyFileExists
  2. LogToSD
public static class Logger
        public static void VerifyFileExists()
            try
                if (!File.Exists(@"SD\Logging\log.txt"))
                    if (!Directory.Exists(@"SD\Logging"))
                        Directory.CreateDirectory(@"SD\Logging");
                    FileStream _fs = File.Create(@"SD\Logging\log.txt");
                    _fs.Flush();
            catch(System.IO.IOException ex)
                Debug.Print(ex.Message);
        public static void LogToSD(string strLog)
            try
                //FileStream fs = new FileStream(@"SD\Logging\log.txt",FileMode.Append,FileAccess.ReadWrite)
            catch(System.IO.IOException exc)
                Debug.Print(exc.Message);
I call these methods from Main:
            Logger.VerifyFileExists();
            Logger.LogToSD("Line One");
            Logger.LogToSD("Line Two");
I always get a Logger folder and a log.txt file, but less than half the time do I have text in my log.txt file as the result of the Logger.LogToSD calls.  Is there something wrong with my design pattern ?
I am running 4.3.2 on a Netduino Plus 2
#2 bgreer5050
bgreer5050
  • 28 posts
Posted 25 June 2015 - 01:38 AM   Best Answer
