SerialPort ESP 8266 ESP8266 Wifi
ESP 8266 ESP 8266 WiFi
10 replies to this topic
#1 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 18 May 2015 - 12:47 PM
Hello I'm trying to interface the ESP8266 WiFi with AT commands.
Also any one intresting in WiFi for the Netduino,
( better just buy the new Netduino 3 with out of the box Wifi !!! :D )
At the moment i'm using the module, with this firmware (0018000902-AI03).
At 9600 bit ps.
most functions are working now.
my problem is the ESP 8266 only have 256 byte buffer. so to read the 256 byte buffer ( 2048 bit. ).
after about 200 ms you start to loose data.
At the moment i spend quite some time to get me familiar to the .net micro framework serial port.
The serial port is read with an interupt.
This interupt is started in a new thread. so this is triggered after some data is recieved.
somtimes 2 bytes somtimes 10 or more.
serialPort.DataReceived += new SerialDataReceivedEventHandler(DataReceived_Interrupt);
serialPort.ErrorReceived += new SerialErrorReceivedEventHandler(ErrorReceived_Interrupt);
Also at first i did not have an Error Revieved interrupt, and was unable to find the problems i had with this module.
turns out it's an buffer input overflow. ( 256 bytes max ).
I changed the handling of the recieved data, and turns out, my approach is to slowy ( or the neduino ? ). For this module.
I'm using some string functions that i suspect are to slowly ?
static System.String sRecieveData = "";
static SerialPort serialPort;
//* Data reception interrupt handler */
internal void DataReceived_Interrupt(object com, SerialDataReceivedEventArgs arg)
  byte[] bytes = new byte[serialPort.BytesToRead];
  // read the bytes
  serialPort.Read(bytes, 0, bytes.Length);
  // convert the bytes into a string
  String strLine = new String(System.Text.Encoding.UTF8.GetChars(bytes, 0, bytes.Length));
  sRecieveData += strLine;
  byte[] buf = new byte[1];
  System.String sRecievePart = "";
  while (serialPort.BytesToRead > 0)
    serialPort.Read(buf, 0, 1);
    sRecievePart += (char)buf[0];
  sRecieveData += sRecievePart;
So my question is what is the best way to handle the recieved serial data ? so i not get the buffer overflow error.
Posted 18 May 2015 - 06:20 PM
Hi JohanV,
Reading data when the interrupt is fired, as you have done, is probably your best option there.
Can you run the module at a higher speed? 9600 bps (~960 characters per second) seems really, really slow. You could overflow your buffer in a quarter of a second (i.e. data is coming in too fast for the serial transport itself). What is the total size of buffers on the module?
#3 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 19 May 2015 - 05:48 AM
There is an AT command to change the baud rate, AT+CIOBAUD.  There's a list here.
#4 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 19 May 2015 - 11:26 PM
This module has only 256 bytes cache. as far as i can test, and read on the internet.
also i did not think about that the data rate could be to slow,
during testing i saw with the interrupt routine many times only get 2 to 4 characters.
but i will change it and see what happens.
i know the baud rate can be changed of this module. it started with 115200, and i thought it would be to fast for netmf.
so it's not the string manipulation that is slow but rather the interupt trigger fired many times ?
if i get serial data back bigger than about 256 bytes the stream is choped at irregular places
thanks
i will try it tomorrow.
#5 Chris Walker
Posted 19 May 2015 - 11:41 PM
Hi JohanV,
I would increase the speed to 57600 or 115200 and then we can go from there.
#6 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 21 May 2015 - 08:41 AM
Actualy, i changed the speed to 115200, and get about 1450 bytes at each http response.
so quite an improvement. Different than i expected....
But some data is still choped, at the end, this is not a real problem, for only sending some simple sensor data to a webserver or database.
I get the "RXOver" type in ErrorReceived_Interrupt(object sender, SerialErrorReceivedEventArgs e)
This is an input buffer overflow ?
So to fix this i need to speed up reading and processing data from the input buffer ?
I'm still wondering what the slow part is of this code (DataReceived_Interrupt) ?
there is an example of the esp8266 driver ( https://github.com/brusdev/ATModem )
this code handles the return data of the module in arrays, i think to avoid slow string processing ?
#7 Chris Walker
Posted 21 May 2015 - 06:51 PM
Hi JohanV,
Progress :) Yay!
I'd start by processing with byte arrays (preferably with a pre-allocated array that you use over and over). Strings are created/destroyed on the fly in memory which requires a lot of RAM and extra processor cycles.
For instance, if you want to add something to string a like this...
string a = "First part of messa";
string b = "ge.";
a = a + b;
...then what is actually happening in the background is something like this...
string b = "ge.";
string c = ... /* creates new string, concatenating "First part of messa" and "ge." */
a = null;
a = c; /* copy string c or assign its pointer to string a */
/* NOTE: b is still hanging around for a while, taking up RAM until it is out of scope and GC'd */
Putting your buffers into byte arrays cuts down on MCU cycles and memory requirements.
#8 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 22 May 2015 - 07:13 AM
Thanks for the support,
I did some string tests.
                this.SendTimeOut = System.DateTime.Now;
                System.String test = "";
                for (int i1 = 0; i1 < 10000; ++i1)
                    test += ":" + i1.ToString();
                Debug.Print(this.SendTimeOut +"::"+ System.DateTime.Now);
this itteration takes about 68 seconds for 10000 repeats.
And turns out it does only 147 times per second the ( += string function ).
so this is only 1200 bytes per second, not fast enough for the 9600 baud rate.
I will look into some array functions to do similar functionality.
I know the STM32F427 is quite fast with array functions.
Any one have some nice example that will run fast ?
#9 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 22 May 2015 - 07:26 AM
Also after getting some serial port data back, and do some string searching.
I did not check how long this takes. an array search will probably be a lot faster ?
                // search string
                    test.IndexOf(":" + i1.ToString());
#10 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 22 May 2015 - 02:57 PM
After some testing i reccomend for serial data processing,
some short code that quickly handles the datarecieved interrupt.
and about a 100 or 150 msec handling the data, but this is al depending on your project off-course.
       private int recBufferLength = 0;
       private byte[] recBuffer = new byte[2048];
             // byte[] buffer = new byte[serialPort.BytesToRead];
             Int32 curRead = serialPort.Read(recBuffer, recBufferLength , serialPort.BytesToRead);
             recBufferLength += curRead;
// i use some sort of data process moment, each 100 or 150 msec.
// at this moment i turn the data into a string.
 sRecieveData += new String(System.Text.Encoding.UTF8.GetChars(recBuffer, 0, recBufferLength));
Also if there is an incomplete http response from the ESP8266, remember how the request was made.
Http1.0 or HTTP1.1.
testing against a linux apache server the HTTP1.1 could use Chunked responses.
( there will be some strange identifier ?? 8d4 in this case.) http://en.wikipedia....ansfer_encoding
+IPD,1059:
1412
HTTP/1.1 200 OK
Date: Fri, 22 May 2015 14:54:29 GMT
Server: Apache/2.2.29 (Unix)
X-Powered-By: PHP/5.4.40
Connection: close
Transfer-Encoding: chunked
Content-Type: text/html; charset=ISO-8859-1
8d4
for a different request i get a response of 39342 bytes.
But still my response with the ESP8266 is choped at around 1450 bytes.
Host: www.netduino.com
Connection: close
Accept: text/html
User-Agent: ESP8266
+IPD,1412:HTTP/1.1 200 OK
Content-Length: 39342
Last-Modified: Sun, 10 May 2015 19:52:13 GMT
Accept-Ranges: bytes
ETag: "2d348ccf5a8bd01:0"
Server: Microsoft-IIS/8.0
X-Powered-By: ASP.NET
Set-Cookie: ARRAffinity=0fc3cc817ad58a64bbaff8bc51eb48d3224777aeb37b322d17e1369cad947f99;Path=/;Domain=www.netduino.com
Date: Fri, 22 May 2015 14:51:24 GMT
Connection: close
?<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR...nsitional.dtd">
<head>
<meta content="en-us" http-equiv="Content-Language" />
<meta content="text/html; charset=utf-8" http-e
#11 H07R0D
H07R0D
  • 95 posts
Posted 10 June 2015 - 01:45 AM
Out of curiosity, how are you powering your setup currently?
I'm just getting started with the ESP and I don't think the 3.3v line on the netduino can power the unit can it?
