Hi Nick,
Grab a copy of the latest Netduino SDK (currently v4.3.2) from the following download link:
http://cdn.netduino....netduinosdk.exe
Then just create a Netduino Application (Universal)...and code away
The new universal template works with all gen2 and gen3 boards and is based on NETMF 4.3.
Thanks for the info. I've now installed v4.3.2.0 and created a new universal app and looks like I can add references to NetduinoGo.RgbLed which is a good start. However, I can no longer see my device in either VS2K13 or MFDeploy.
The other day I upgraded my N3 firmware to 4.3.2.1 and I could see my device fine in both. Any ideas what how I can fix it?
If I emulate the app instead of deploying it (as I can't) I get the following errors in the output window;
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\GoBus.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\NetduinoGo.RgbLed.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Applications\Netduino\NetduinoApplicationUniversal\NetduinoApplicationUniversal\bin\Debug\le\NetduinoApplicationUniversal.exe', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Hardware.Netduino.dll', Symbols loaded.
'Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Hardware.dll', Symbols loaded.
#### Exception System.ArgumentException - 0xfd000000 (2) ####
#### Message:
#### Microsoft.SPOT.Hardware.HardwareProvider::NativeGetSpiPins [IP: 0000] ####
#### Microsoft.SPOT.Hardware.HardwareProvider::GetSpiPins [IP: 0013] ####
#### Microsoft.SPOT.Hardware.SPI::.ctor [IP: 0019] ####
#### GoBus.GoHub::Initialize [IP: 00ad] ####
#### GoBus.GoModule::Initialize [IP: 0099] ####
#### GoBus.GoModule::.ctor [IP: 0016] ####
#### GoBus.GoHub::.ctor [IP: 0004] ####
#### GoBus.GoHub::.cctor [IP: 0003] ####
A first chance exception of type 'System.ArgumentException' occurred in Microsoft.SPOT.Hardware.dll
An unhandled exception of type 'System.ArgumentException' occurred in Microsoft.SPOT.Hardware.dll
Uncaught exception
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### GoBus.GoModule::Initialize [IP: 0021] ####
#### NetduinoGo.RgbLed::.ctor [IP: 0040] ####
#### NetduinoApplicationUniversal.Program::Main [IP: 0004] ####
A first chance exception of type 'System.NullReferenceException' occurred in GoBus.dll
An unhandled exception of type 'System.NullReferenceException' occurred in GoBus.dll
Uncaught exception
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
Done.
The program '[5732] Micro Framework application: Managed' has exited with code 0 (0x0).
The code I'm using is as follows;
using System.Net;
using System.Net.Sockets;
using NetduinoGo;
namespace NetduinoApplicationUniversal
var x = new RgbLed();
x.SetColor(255, 0, 0);
All references in project:
GoBus.dll - V1.5.0.0
Microsoft.SPOT.Hardware - V4.3.1.0
Microsoft.SPOT.Hardware.PWM - V4.3.1.0
Microsoft.SPOT.Hardware.SerialPort - V4.3.1.0
Microsoft.SPOT.Native - V4.3.1.0
Microsoft.SPOT.Net - V4.3.1.0
mscorlib - V4.3.1.0
NetduinoGo.RgbLed - V1.4.0.0
SecretLabs.NETMF.Hardware - V4.3.1.0
SecretLabs.NETMF.Hardware.Netduino - V4.3.1.0
System - V4.3.1.0
Even if I just try a vanilla app it gives me the same exception in the Microsoft.SPOT.Hardware.dll.
All I want to do is make my Led change colour ;(.
Any help is much appreciated!
Nick
