Version: 4.3.2 Beta 1 (version 4.3.2.0 beta 1)
Download link
Download Netduino Go v4.3.2 beta 1 firmware now
NOTE: This beta firmware does not yet support use of Shield Base (beta). We will be adding support for Shield Base Virtual I/O progressively throughout the Netduino Go 4.3.2 beta program.
Updates in this release
1. Streamlined "Netduino Application" universal template now supported
2. .NET Micro Framework 4.3.1 now supported.
Pre-requisites for this firmware
1. Visual Studio 2012 or Visual Studio 2013. Or Visual Studio 2015 (beta).
2. .NET Micro Framework SDK v4.3 QFE2 or newer
3. NETMF plug-in for Visual Studio 2012, NETMF plug-in for Visual Studio 2013 or NETMF plug-in for Visual Studio 2015 (beta).
4. Netduino SDK v4.3.2.1 or newer
How to flash this firmware
1. Detach your Netduino from your computer to turn it off.
3. Run the Netduino Update tool (see download link above).
a. If your device does not appear, install the STDFU drivers + tools v3.0.3.
b. If your device appears as "STM Device in DFU Mode", click on "Options", select your board type from the Product selection box and close the Options window.
4. Select the checkbox next to your device and press "Upgrade"
5. Wait while the upgrade operation completes. After flashing, your Netduino will reboot and will be removed from the upgrade list.
How to find your current version of Netduino firmware
1. Go to the Start Menu > Programs > Microsoft .NET Micro Framework 4.3
2. Run MFDeploy.
5. Select the Target menu > Device Capabilities option.
Download link
Netduino Go Firmware v4.3.2 (beta 1)
Started by Chris Walker, May 09 2015 05:35 AM
No replies to this topic
