Netduino Plus 2 Firmware v4.3.2
#1 Chris Walker
Posted 29 April 2015 - 06:10 AM
Version: 4.3.2 (version 4.3.2.0)
Download link
Download Netduino v4.3.2 firmware now
Updates in this release
1. Streamlined "Netduino Application" template now supported
2. Bugfix: COM2 flow control now enabled
3. Bugfix: System.Net HTTP classes now check for null during Dispose
Pre-requisites for this firmware
1. Visual Studio 2012 or Visual Studio 2013. Or Visual Studio 2015 (beta).
2. .NET Micro Framework v4.3 QFE2 SDK or newer
3. NETMF plug-in for Visual Studio 2012, NETMF plug-in for Visual Studio 2013 or NETMF plug-in for Visual Studio 2015 (beta).
4. Netduino 4.3.1 SDK or newer
How to flash this firmware
1. Detach your Netduino from your computer to turn it off.
3. Run the Netduino Update tool (see link above).
a. If your device does not appear, install the STDFU drivers + tools v3.0.3.
b. If your device appears as "STM Device in DFU Mode", click on "Options", select your board type from the Product selection box and close the Options window.
4. Select the checkbox next to your device and press "Upgrade"
5. Wait while the upgrade operation completes. After flashing, your Netduino will reboot and will be removed from the upgrade list.
6. After flashing, set your network settings using MFDeploy. In MFDeploy, select the Target > Configuration > Networking menu. Re-enter your IP address settings and MAC address.
How to find your current version of Netduino firmware
1. Go to the Start Menu > Programs > Microsoft .NET Micro Framework 4.3
2. Run MFDeploy.
5. Select the Target menu > Device Capabilities option.
Download link
#2 GeBrander
GeBrander
  • 29 posts
Posted 29 April 2015 - 07:27 PM
Does it have to do with the Build event?
#3 Chris Walker
Posted 29 April 2015 - 07:43 PM
Hi GeBrander,
Without answering that question directly...
The new firmware is designed to work side-by-side with firmware for...two other new boards :)
