Input as event
Best Answer brianmakabro, 16 April 2015 - 07:25 PM
How about something like:
    public enum Modes
         ModeUnknown,
         Mode1,
         Mode2,
         Mode3
       static OutputPort interuptled = new OutputPort(Pins.ONBOARD_LED, false);
       static Modes currentMode = Modes.ModeUnknown;
            InterruptPort button = new InterruptPort(Pins.ONBOARD_SW1, false,
                                     Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
            button.OnInterrupt += new NativeEventHandler(button_OnInterrupt);
            currentMode = Modes.Mode2;
        static void button_OnInterrupt(uint data1, uint data2, DateTime time)
            switch (currentMode)
                case Modes.Mode1:
                    interuptled.Write(!interuptled.Read());
                    break;
                case Modes.Mode2:
                    // DO MODE 2 WORK...
                    break;
                case Modes.Mode3:
                    // DO MODE 3 WORK...
                    break;
                default:
                    // UNKNOWN MODE?  RAISE ERROR?
                    break;
5 replies to this topic
#1 kalio20
kalio20
  • 22 posts
Posted 16 April 2015 - 11:23 AM
is it possible to wait for a signal for example on Pin 9 for a high or low signal and start an interreupt or event on this signal?
Greets
Zoro
#2 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 16 April 2015 - 11:49 AM
Hi Kalio,
An InterruptPort can be configured to call an eventhandler in response to an EdgeLow, EdgeHigh, EdgeBoth, EdgeLevelHigh, or EdgeLevelLow transition(s) on a pin.
You may need to add "debounce" logic to your code.
@KiwiBryn
blog.devmobile.co.nz
#3 kalio20
kalio20
  • 22 posts
Posted 16 April 2015 - 12:20 PM
Ok, thanks that helps me alot, but is there a way to activate the interrupt or similar just when i need it? For example if i got 3 Modes, and i am in Mode 2, and it start execute when i got my interrupt on Pin.Any..., but if i am in Mode 3, then the interrupt should be blocked and only available for Mode 2?
Thanks in advance
kalio!
#4 KiwiDev
KiwiDev
  • 100 posts
Posted 16 April 2015 - 07:16 PM
Hi Zoro,
If you just want to activate/deactivate the interrupt in specific state(s) then have a look at
         button.DisableInterrupt();
         button.EnableInterrupt();
You could call these from your state machine logic
@KiwiBryn
#5 brianmakabro
brianmakabro
  • 12 posts
  • LocationLouisville, KY
Posted 16 April 2015 - 07:25 PM   Best Answer
    public enum Modes
         ModeUnknown,
         Mode1,
         Mode2,
         Mode3
                case Modes.Mode1:
                    break;
                case Modes.Mode2:
                    break;
                case Modes.Mode3:
                    break;
                default:
                    break;
#6 kalio20
kalio20
  • 22 posts
Posted 17 April 2015 - 08:40 AM
Thank u very much for ur answers!
They really help me alot, and is easy to understand!
Very thank you!
Greets
kalio
