Serial Port read data
1 reply to this topic
#1 kalio20
kalio20
  • 22 posts
Posted 14 April 2015 - 10:52 AM
my problem is that i have to read 1 single byte from the serial port, is this possible without using the s.port as event or interrupt? Cause I have to decide on my input wich task i want to run, for example input = 1, do blabla, input = 2, do different blabla. Or would u recommend me a better way for my input needings? Sadly there is no input console.
Greets
Zoro
#2 baxter
baxter
  • 415 posts
Posted 14 April 2015 - 05:57 PM
I was using this with an ESP8266 AT command set driver (since abandonded in favor of the Lua firmware). Just instantiate the port without an event handler and then receive serial in a wait loop.
Public Sub New(ByVal ComPort As String, _
                   Optional ByVal baud As Integer = 9600)
        Port = New SerialPort(ComPort, baud, Parity.None, 8, StopBits.One)
        With Port 'note no event handler
            .Handshake = Handshake.None
            .WriteTimeout = 200
            .ReadTimeout = 200
            .Open()
        End With
        InputString = String.Empty
        'need to change if not 9600
        If (baud <> _DefaultBaud) Then '9600 is default baud rate of ESP8266 firmware (0.9.2.2)
            _Baud = baud
        End If
    End Sub
Public Function GetFromESP(Eot As String) As String
        'this is the main reader for ESP responses. It will wait for the expected Eot or
        'a socket exception will be thrown if the response contains, ERROR or Unlink
        Dim n As Integer = 0
        Dim response As String = String.Empty
        While (True)
            If (Port.BytesToRead > 0) Then
                Dim buff = New Byte(Port.BytesToRead - 1) {}
                n = Port.Read(buff, 0, Port.BytesToRead)
                Thread.Sleep(200)
                InputString &= New String(Encoding.UTF8.GetChars(buff))
                'Debug.Print("Inputstring: " & InputString)
                If (Contains(InputString, Eot)) Then 'expected return
                    Exit While
                    'Trap for socket connect to inactive server
                ElseIf (Contains(InputString, "CIPSTART") And _
                       (Contains(InputString, "ERROR") _
                        Or Contains(InputString, "Unlink"))) Then
                    response = InputString
                    Throw (New ESPexception("Socket can't connect: GetFomESP returned ERROR Unlink"))
                End If
                Thread.Sleep(50) 'need this delay (maybe more)
            End If
        End While
        Return response
    End Function
