Netduino + 2 I2C with VNCL4000 Proximity Sensor
i2c proximity sensor netduino plus 2
6 replies to this topic
#1 pajama
pajama
  • 4 posts
Posted 14 April 2015 - 12:18 AM
Dear Netduino Community,
I'm having a hard time writing this I2C driver. I've looked through a number of tutorials/examples, but everything I try always throws a System.ArgumentException, without much information.
I'm trying to get this little proximity/ambient light sensor up and running with a Netduino Plus 2:
http://www.adafruit....ts/vcnl4000.pdf
The important bit in that data sheet is probably the example application:
Addressing:command: 26h, 85h (VCNL4000_I2C_Bus_Write_Adr., Ambient Light Result Register #5 [85]) Read register #5:command: 27h, data (VCNL4000_I2C_Bus_Read_Adr., {High Byte Data of Ambient Light Result Register #5 [85])} Read register #6:command: 27h, data (VCNL4000_I2C_Bus_Read_Adr., {Low Byte Data of Ambient Light Result Register #6 [86])}
I can't find any other netduino I2C examples that are remotely similar. I would really appreciate any advice! Maybe if someone can help me figure out the most basic example of reading command register #1 (product ID), that would give me a huge step in the right direction.
I've attached a VS project if anyone cares to check it out.
Thank you for your time!
#2 scardinale
scardinale
  • 27 posts
  • LocationNew York, USA
Posted 16 April 2015 - 02:05 PM
@pajama
A couple of things that might be causing your difficulties:
  • You are using a 8-bit I2C address in your code. (0x27) and it needs to be a 7-bit address (0x13).
  • Your I2C clock is set too high. I do not think that the Net Micro Framework supports clock at 3400. Try setting your clock to 100 and then (if successful) try a higher clock (400).
#3 pajama
pajama
  • 4 posts
Posted 16 April 2015 - 09:30 PM
Thank you for the reply! I changed the values above. Still throwing an exception here:
 if (transferred != writeBuffer.Length)
                    throw new Exception("Could not write to device.");
Any ideas?
#4 scardinale
scardinale
  • 27 posts
Posted 17 April 2015 - 01:17 AM
I would try using the WriteRegister and ReadRegister methods rather than the generic Write and Read methods.
#5 pajama
pajama
  • 4 posts
Posted 17 April 2015 - 08:10 PM
Thank you for the suggestion.
Here's what I'm doing, still getting the same error. Should my writebuffer be a different size?
 public byte ReadVersion()
            // write register address
            byte[] writeBuffer = new byte[1];
            I2CBus.GetInstance().WriteRegister(_slaveConfiguration, (byte)CommandRegisters.ProductId, writeBuffer, TransactionTimeout);
            // get the byte result
            byte[] data = new byte[1];
            I2CBus.GetInstance().ReadRegister(_slaveConfiguration, (byte)CommandRegisters.ProductId, data,TransactionTimeout);
            //force the convertion to a signed byte
            return data[0];
#6 pajama
pajama
  • 4 posts
Posted 17 April 2015 - 08:15 PM
_slaveDevice.Execute(writeXAction, transactionTimeout) is returning 0
#7 scardinale
scardinale
  • 27 posts
Posted 17 April 2015 - 08:43 PM
@pajama, did you get the PM that I sent to you?
I would drop the first WriteRegister call and only use the ReadRegister call.
Also tagged with one or more of these keywords: i2c, proximity sensor, netduino plus 2
