Controlling Multiple I2C devices
howto i2c iic NetMF 4.3
8 replies to this topic
#1 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 20 March 2015 - 11:33 PM
I need to control multiple I2C devices on the same bus. This seems like a reasonable requirement since I2C is inherently designed as a multi-master bus. However, when I try to create two devices, I get an exception on creating the second device. Example:
            var i2c1 = new I2CDevice(new I2CDevice.Configuration(0x60, 10));
            var i2c2 = new I2CDevice(new I2CDevice.Configuration(0x7B, 40));
I get an InvalidOperationException on the second line.
Looking into the firmware source, it looks like it is because I2CDevice is trying to reserve the output pins twice, which fails. Surely, they don't expect me to create a new instance of I2CDevice for each and every transaction? That just seems mega inefficient.
Any I2C users out there had similar problem? What's the right way to manage multiple devices?
#2 Mario Vernari
Posted 21 March 2015 - 05:16 AM
I never tried I2C on Netduino, but it sounds like other ports, which have to be disposed to be reused. This is surely a elegant yet reliable solution, but -agree- not so efficient.
Did you try to swap the configuration instead of creating many instances of I2CDevice?
#3 brianmakabro
brianmakabro
  • 12 posts
  • LocationLouisville, KY
Posted 22 March 2015 - 01:56 AM
Absolutely can be done, instantiate multiple Configurations and just set device.Config = configX.
#4 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 22 March 2015 - 10:43 PM
Ok thanks for the suggestions. I have tried setting the configuration property and that works, so I have a way forward. I can't help feeling that this is a leaky abstraction though, because an I2CDevice is not the same thing as the entire bus; the pins should belong to the bus, not the device. At least I have a workaround.
--Tim
#5 brianmakabro
brianmakabro
  • 12 posts
Posted 22 March 2015 - 11:45 PM
I think it may have been done that way because of the "Netduino as master-only."  It's very similar to the way MS did their Point-Of-Sale architecture.  It's really not very intuitive, at first. (IMHO, of course.)  But then since ND can only be the master, it IS the I2CDevice - and the slaves are all just so many connections.
#6 Mario Vernari
Posted 23 March 2015 - 08:05 AM
Tim, I'm 100% with you, but abstraction comes at a cost and Micro Framework tries to solve high-level problems on (relatively) very poor hardware.
Swapping the config is surely cheap in term of computation, but of course leaks in term of abstraction. However, you might think the I2Device as the "I2C logic driver", and the various configs as "instances" of this driver. Such a viewpoint comes maybe a little closer to the abstract-hardware model.
Good luck!
#7 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 25 March 2015 - 07:12 AM
The more I think about it, the more I feel that it is a disastrous design. Consider what you have to do to have different devices running on multiple threads accessing an I2C device!! (which I do).
I have come up with a tentative solution by simply wrapping the I2CDevice class in something a bit more intelligent, I am still testing it to see if it has any impact on performance. I will post something if and when I have a viable solution.
--Tim
#8 EddieGarmon
EddieGarmon
  • 24 posts
Posted 25 March 2015 - 03:32 PM
I have done the same, but went as far as a true interface for a bus and another for a device. now I can plug in a mock bus for driver testing, and a spot bus for working on a netduino.
https://github.com/E...er/Hardware/I2C
#9 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 28 March 2015 - 03:40 AM
I might be missing something, but there are many wrapper classes available for supporting multiple devices on the I2C bus e.g.
Netduino wiki
http://wiki.netduino...ass.ashx?HL=i2c
or
NetMF Toolbox see multiII2C.cs
http://netmftoolbox.codeplex.com
I am using an enhanced version of the wiki sampe to access multiple devices on the same I2C bus
@KiwiBryn
blog.devmobile.co.nz
