How to add the missing byte shifter operators to a vb.net
create dll shifter operators c# in VB
5 replies to this topic
#1 David Weaver
David Weaver
  • 50 posts
  • LocationBloomington IL
Posted 06 February 2015 - 05:48 PM
How to add the missing byte shifter operators to a vb.net Netduino Project
  1. Start a new Netduino C# project
  2. Locate the projects properties page and select the target framework your vb.net project will be using mine was 4.2. Next change the Output Type to Class Library.
  3. Locate the main menu item Build and find the Configuration manager. Then change the configuration from debug to release. This will allow you to build a dll you can use in all your projects in debug mode you would need many more files.
  4. Add a code file to the project and remove the program.cs file
 Add this code to it:
namespace ByteShifter
    public class ByteShifter
        public  byte ShiftRight(byte bytetoshift, int placestoshift)
            byte ShiftedByte = (byte)(bytetoshift >> placestoshift);
            return ShiftedByte;
        public byte ShiftLeft(byte bytetoshift, int placestoshift)
            byte ShiftedByte = (byte)(bytetoshift << placestoshift);
            return ShiftedByte;
  1. Build the solution and locate the release directory under solution directory the new dll should be there.
  2. Start of vb.net project and add a reference to the dll just created (I like to copy the dll to the vb.net debug directory and then add a reference to the vb.net project).
  3. Below is an example of how to use the new byte shifting functions in the dll you created
Imports Microsoft.SPOT
Imports SecretLabs.NETMF.Hardware.Netduino
Imports ByteShifter 'new byte shifter functions
Module Module1
    Sub Main()
        'Create an object
        Dim obj As New ByteShifter.ByteShifter
        'Dim b As Byte = 8 >> 2
        Dim b As Byte = obj.ShiftRight(8, 2)
    'output should be 2
        Debug.Print("The 8 >> 2 answer is: " & b.ToString)
        Dim b1 As Byte = 155
        ' Dim b2 As Byte = b1 >> 1
        Dim b2 As Byte = obj.ShiftRight(b1, 1)
        'output should be 77
        Debug.Print("The answer for b2 is: " & b2.ToString)
        Dim b3 As Byte = 154
        'Dim b2 As Byte = b1 << 1
        Dim b4 As Byte = obj.ShiftedLeft(b3, 1)
        'output should be 52
        Debug.Print("Left Shifted b4 is:" & b4.ToString)
    End Sub
End Module
#2 scardinale
scardinale
  • 27 posts
  • LocationNew York, USA
Posted 06 February 2015 - 11:17 PM
Simpler yet is to add these two extension methods to your project.
<System.Runtime.CompilerServices.Extension> _
Public Shared Function RightShift(integerToShift As Integer, bitsToShift As Integer) As Integer
    Return CInt(integerToShift / 2 ^ bitsToShift)
End Function
Public Shared Function LeftShift(integerToShift As Integer, bitsToShift As Integer) As Integer
    Return CInt(integerToShift * 2 ^ bitsToShift)
End Function
#3 David Weaver
David Weaver
  • 50 posts
Posted 07 February 2015 - 12:30 AM
Thank you for the solution you are right this is far better!!!
#4 David Weaver
David Weaver
  • 50 posts
Posted 07 February 2015 - 12:44 AM
I just tried adding the code and got a bunch of errors could you give me an example of how to implement the functions thanks for the help in advance.
#5 David Weaver
David Weaver
  • 50 posts
Posted 07 February 2015 - 01:58 AM
OK long day works great!!
#6 scardinale
scardinale
  • 27 posts
Posted 07 February 2015 - 02:10 AM
Glad you got it working. That's what the community is about, sharing knowledge.
