Help me out with SPI Please.
10 replies to this topic
#1 david98xp
david98xp
  • 57 posts
Posted 03 February 2015 - 12:18 AM
I have this thread on GHI and am trying to get my netduino 2 working with my glcd(st7565).
Almost all info you need is there.
Help me fix fabien's driver so something will come up on my lcd. There is also a onedrive link you can check out.
https://www.ghielect...id=18209&page=4
#2 Mario Vernari
Posted 03 February 2015 - 06:31 AM
The Netduino 2 Plus had some issues related to the SPI, and should have been fixed with the latest firmware.
That was sure for the Netduino Plus 2: not sure about the simpler Netduino 2.
Those issues were mostly related to the worse SPI hardware logic in the ST chip, than the older Atmel.
#3 herbsti72
herbsti72
  • 12 posts
  • LocationVienna, Austria
Posted 03 February 2015 - 01:36 PM
Hi David,
a few days ago I got ST7565 (Adafruit) working with my Netduino 2 Plus (see attachment).
I use the "AdaFruit ST7565 Negative LCD display" driver available in Netduino Helpers Library and it worked fine out of the box.
How is your ST7565 wired with Netduino?
At least you need to wire following pins (the bold ones you need to set on AdaFruit7565 constructor) :
GND:  GND
VDD:  3.3v
SID:  D11 (SPI MOSI)
SCLK: D13 (SPI CLK)
A0:   D7 (Data / Command)
/RST: D4
/CS:  D10 (or D8)
These pins are just for background light and are optional (so you can leave it unplugged for first tests):
B-:   LED Blue
G-:   LED Green
A+:   LED anode
R-:   LED Red
How to use AdaFruit7565 class in your code:
For creating instance of AdaFruit7565 class you need to take care to set correct pins (marked above red!) in constructor!
Here is some sample you can use in program.cs:
using System;
using System.Threading;
using Microsoft.SPOT;
using Microsoft.SPOT.Hardware;
using SecretLabs.NETMF.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
using netduino.helpers.Hardware;
namespace AdaFruit7565Test {
    public class Program {
        // you need to reflect pin configuration in AdaFruit7565 constructor
        public static AdaFruit7565 lcd =
           new AdaFruit7565(Pins.GPIO_PIN_D7, Pins.GPIO_PIN_D4, Pins.GPIO_PIN_D10, speedKHz: 21000);
        public static void Main() {
            lcd.Initialize();     // init display - important!
            lcd.SetContrast(AdaFruit7565.ContrastMedium);
            lcd.DrawString(0, 1, "Test");
            lcd.Refresh();        // refresh screen and shows text
            Thread.Sleep(5000);   // wait 5 seconds before set powersavemode
            lcd.ClearScreen();
            lcd.DrawString(0, 1, "Test 2");
            lcd.PowerSaveMode();  // set display to powersave mode
What happens if you try above code?
br,
Johannes
#4 david98xp
david98xp
  • 57 posts
Posted 04 February 2015 - 04:46 AM
Thanks but it didin't work. Even when I tried setting it to SPI module 2(according to the N2 schematics). I'm surprised it worked out of the box. Maybe it was designed only for the PLUS. I don't know what else I must do to get the lcd working on this hardware.
#5 herbsti72
herbsti72
  • 12 posts
Posted 04 February 2015 - 09:48 AM
Which firmware have you installed on your Neduino 2?
#6 CW2
Posted 04 February 2015 - 10:06 AM
Could you post a photo of the actual wiring?
#7 david98xp
david98xp
  • 57 posts
Posted 04 February 2015 - 08:44 PM
I'm running 4.2. Here are the photos of wiring and the "result".
Link:https://onedrive.live.com/redir?resid=95EDA52E6601F7B0!18018&authkey=!ALH6P7svj1YQ3WA&ithint=folder%2c photos in the root.
How do you upload anyway :P
#8 herbsti72
herbsti72
  • 12 posts
Posted 04 February 2015 - 10:34 PM
At first I would upgrade to 4.3.1 so maybe there is a fix for SPI in newer version of MF.
Or is there some reason why you stuck on 4.2?
Second - on your pictures I cannot identify your wiring ;)
I have attached my wiring so you could compare it to yours... hope it helps :-)
#9 herbsti72
herbsti72
  • 12 posts
Posted 04 February 2015 - 10:38 PM
I need to use Firefox - IE 10 doesnt work very well with this forum ;-)
Right below of the edit box there is a "more reply options" button - if you click on this you are able to attach pictures and other documents to your post.
#10 david98xp
david98xp
  • 57 posts
Posted 27 March 2015 - 02:56 AM
Ok Nerbsti72
I have 4.31 with VS2012 now. The blink test works but this still gives me a white backlight of death. I looked at schematics and also tried setting it to SPI module 2.
I'm surprised it worked out of the box for you..
#11 herbsti72
herbsti72
  • 12 posts
Posted 29 March 2015 - 09:57 AM
sad to hear that it is still not working. :(
Last weekend I attached another Adadfruit LCD on my N2+ and it worked.
Maybe you have some wrong wiring?
Or something went wrong during soldering (cold solder joints)?
