Hey Guys,
I am writing a small Netduino+2 application, which will communicate with the Phillips HUE light bridge controller. This should be a simple task, in that the all I am doing is sending simple Http requests to the bridge (which I can do sucessfully).
The problem however, is when I try to process/parse the responses. Right now, I am experiencing three strange issues using the HttpWebResponse and Stream objects.
1. HttpWebResponse.ContentLength is always equal to "-1", even thought there is always body content (application/json content).
2. HttpWebResponse.GetResponseStream() seems to be unstable, in that it will sometimes truncate the response for longer responses (~700 bytes +). Putting in a Thread.Sleep(500) right after seems to help this for some reason. I don't know why.
3. Stream.Read() seems to be unstable, in that it will truncate near the end of stream (return 0) for the larger response.
Below is my code. I need this to be able to process around 2KB responses at least. I am running the latest framework 4.3. Anyone have any ideas?
public static string Send(string uri, string method, string body, bool ignoreResponse = true) { try { using (HttpWebRequest req = (HttpWebRequest)WebRequest.Create(new Uri("http://" + bridgeIP + "/api/" + bridgeUser + "/" + uri))) { req.Method = method; req.ContentType = "text/plain;charset=UTF-8"; req.Timeout = 3000; //3s req.ReadWriteTimeout = 3000; req.KeepAlive = false; if (body != null && body != "") { byte[] buffer = Encoding.UTF8.GetBytes(body); req.ContentLength = buffer.Length; using (Stream PostData = req.GetRequestStream()) { PostData.Write(buffer, 0, buffer.Length); PostData.Close(); } } else { req.ContentLength = 0; } Debug.Print("Sending " + method + " request to: " + uri); HttpWebResponse resp = (HttpWebResponse)req.GetResponse(); string responseString = ""; int contentLength = (int)resp.ContentLength; if (!ignoreResponse)// && contentLength > 0) { //Otherwise process response using (Stream responseStream = resp.GetResponseStream()) { System.Threading.Thread.Sleep(500); //This seems to help fix the following line (responseStream.Length) int responseLength = (int)responseStream.Length; Debug.Print("Response with length " + responseLength.ToString() + " received. Processing..."); if (responseLength <= 0) return null; //write to responseString in chunks of 256 bytes byte[] c = null; while (true) { c = new byte[256]; if (responseStream.Read(c, 0, c.Length) == 0) break; responseString += new string(Encoding.UTF8.GetChars(c)); } } } resp.Close(); resp.Dispose(); req.Dispose(); Debug.Print("Response Processed. Length of:" + responseString.Length.ToString()); return responseString == "" ? null : responseString; } } catch (Exception e) { Debug.Print(e.ToString()); } return null; }
