First project advice for hardware: Temperature, humidity and wifi - General Discussion - Netduino Forums
7 replies to this topic
#1 donkraft
donkraft
  • 4 posts
Posted 30 December 2014 - 09:23 AM
After many years of lurking (and some drooling), I think it is about time that I get my hands dirty with something simple and actually useful in this space. But I can see that so much has happened since I was last looking into this a few years ago, and it seems picking the right hardware is a bit of a jungle, so I really would appreciate some help with that to get the first project off the ground.
My first project will be a simple logger of temperature and humidity. Something along the lines of:
- Every 10 minutes, read temperature and humidity
- Send it to a URL I config (http://heat.mydomain...=35&humidity=61)
Version 1:
- Ethernet and battery (I understand this is the simplest (or at least used to be))
Version 2:
- Wifi and battery
Version 3:
- Wifi and outlet power (230v)
Requirements:
- .Net code
- 100$/€ budget
Priorities:
1. I want to get an easy win under my belt with as little hassle as possible.
2. Cost is less important, I don't want to save money and have to spend more time fiddling with drivers etc
The question:
Which specific devices should I buy to achieve this in the easiest way possible?
#2 ShVerni
ShVerni
  • 138 posts
  • LocationNew York, New York
Posted 03 January 2015 - 03:59 AM
Hello and welcome!
If you want to get accurate, and easy, temperature and humidity readings I recommend HIH6130. It's not the cheapest out there, but it easy and quick to get up and running:
http://forums.netdui...er-hih6130-i2c/
You could also try the cheaper HTU1D, but I have no experience with that, so I can't tell you how it would work, but it looks simple enough.
http://forums.netdui...umidity-sensor/
Good luck!
#3 donkraft
donkraft
  • 4 posts
Posted 03 January 2015 - 08:53 PM
Thanks for the feedback!
I had to order what I could find in coolcomponents.co.uk, as I did not want to ship from many places, and it was more practical to order from inside EU..
I picked the NetDuino Plus 2 Starter Kit, some extra small stuff and I then picked a cheaper temparature sensor to begin with -the TMP012. Then I can add the much more expensive HIH6130 if I need the extra precision later. :)
#4 donkraft
donkraft
  • 4 posts
Posted 03 January 2015 - 09:46 PM
This is the stuff I ordered:
Digital Temperature Sensor Breakout - TMP102 478 1 €4.84 Breadboard Deluxe 720 1 €5.29 NetDuino Plus 2 Starter Kit 764 1 €68.71 Netduino Plus 2 .NET / C# Development Board       1 x Netduino Plus 2 .NET / C# Development Board €0.00 1074     Breadboard Mini (Blue)       2 x Breadboard Mini (Linkable, Blue) €0.00 1187     Jumper Wires - Female to Female       1 x Jumper Wires - Female to Female €0.00 199     Jumper Wires - Male to Male       1 x Jumper Wires - Male to Male €0.00 175     Piezo Buzzer       1 x Piezo Buzzer €0.00 341     Tilt Switch - 15 degrees       2 x Tilt Switch - 15 degrees €0.00 340     Component Box 6B       1 x Component Box 6B €0.00 668     USB A to micro B Cable       1 x USB A to micro B Cable €0.00 625     LED - Red 3mm       2 x LED - Red 3mm €0.00 213     LED - Yellow 3mm       2 x LED - Yellow 3mm €0.00 215     LED - Green 3mm       2 x LED - Green 3mm €0.00 214     Transistor NPN BC547B       2 x Transistor NPN BC547B €0.00 327     Switch - Mini Tactile PCB       2 x Switch - Mini Tactile PCB €0.00 202     Resistor 220K 0.25W       5 x Resistor 220K 0.25W €0.00 338     Resistor 220R 0.25W       5 x Resistor 220R 0.25W €0.00 336     Resistor 10K 0.25W       5 x Resistor 10K 0.25W €0.00 339     Diode 1N4001       2 x Diode 1N4001 €0.00 343     Opto Isolator 4N35       2 x Opto Isolator 4N35 €0.00 342     Hitec Servo Motor HS-422 235 1 €15.26 Alligator Test Leads - Multicolored 10 Pack 1347 1 €2.34 Getting Started with Netduino 960 1 €12.91
Is there anything else I need to get started? Do I need a soldering iron for example?
Edit: Formatting fucked, sorry :(
#5 ShVerni
ShVerni
  • 138 posts
Posted 04 January 2015 - 04:10 AM
I don't know much about that sensor, but that looks good. You won't need a soldering iron to do breadboard work, but if you want to make something more permanent, they're indispensable. The only thing is, you'll need a good amount of jumper wires (upwards of a dozen at least), so as long as you have that it looks like you're off to a great start. Please do keep us informed of how things go!
Best of luck!
#6 donkraft
donkraft
  • 4 posts
Posted 05 January 2015 - 09:37 AM
Thanks! :)
The stuff is backordered with Coolcomponents.co.uk, so I have time to add a few extra things.
Starting from completely blank slate and knowing less than nothing about this whole area, so I am sure this is a stupid question, but here goes:
Would The jumper cables you talk about, would that be something like these:
Male to Male Jumper Wire Variety Pack
https://www.coolcomp...riety-pack.html
Do I need some female ones as well?
#7 Spiked
Spiked
  • 129 posts
Posted 05 January 2015 - 05:10 PM
Yes.  If you think you are going to stick with it, invest in good crimpers, and get some female ends, and just make a few as you need them.
The thing is, from a practical point of view, you can make a female male by adding a pin, not so much the other way around. But a male will have a more solid connection, so I dont know if I would get all females.  I ended up with a bunch of both.  Last project needed male to female :|
#8 ShVerni
ShVerni
  • 138 posts
Posted 05 January 2015 - 10:35 PM
Agreed. I have a large supply of every possible type of jumper, and the all come in handy. Still, for just starting out, the male-male will be most useful if everything is being done on a breadboard, but it never hurts to have more jumpers!
