MVC web framework like web server experience on Netduino
7 replies to this topic
#1 Fredde
  • 8 posts
Posted 23 December 2014 - 02:36 PM
I would like to share a project i have been working with for a long time, it gives you a MVC like developer experience on Netduino.
To initialize the server:
        var webServer = new WebServer();
To create your first controller:
public class MyFirstController : Controller
    public void Index()
        SetHtmlResult("<!DOCTYPE html><html><body><h1>My page</h1></html>");
Then run or similar.
The main features is:
  • Controller/Action based web request routing with model binding and HTML or JSON response types built in.
  • It support both GET and POST http methods.
  • Exception handling with generic error response that includes exception message and stack trace.
  • It support static files via an optional assembly(to save code space if not needed).
  • Filters on request and response for things like logging, authentication and other things.
It is built with Dependency injection and has some Unit tests.
For source code with running examples and some more decumentation see
And for long running scenarios i really recommend adding some kind of hardware based watch guard.
#2 bulletprooffool
  • 12 posts
Posted 10 February 2015 - 04:25 PM
That's very cool!
I'll have to see what I need to change to use this on an older version of NetMf (since 4.3 will seemingly never be supporter on my old Netduino plus 1s) - and since arduino clones now cost nothing and there are new offerings like the Raspberry Pi update available at about the same price point as the Netduino, I just can't see myself paying for an upgrade.
Irrespective, super work!!
#3 Frode
  • 202 posts
  • LocationNorway
Posted 15 February 2015 - 06:21 PM
Very cool! Nice job!
#4 Fredde
  • 8 posts
Posted 26 February 2015 - 02:18 PM
I think this will run fine on any 4.x version without any larger modifications except the missing string builder in older versions, but that can be fixed with the one in this post:
The limited amount of memory will not be a problem for simpler applications.
#5 Sukasa
  • 32 posts
  • LocationNanaimo, BC
Posted 30 March 2015 - 08:11 PM
This is pretty awesome, I think I might have to make use of this in a reflow oven project I'm working on...
#6 cr0w5t3r
  • 9 posts
  • LocationUK
Posted 10 May 2015 - 09:05 PM
I work with MVC 4/5, Web Api on a daily basis so any linking to those types of frameworks makes me excited!
I will have to test it this week and let you know how it goes  ^_^
#7 lancewmccarthy
  • 9 posts
  • LocationBoston, MA USA
Posted 02 June 2015 - 08:43 PM
This is very cool! I'm having a problem... although it shows as it is running, any attempt to connect to the server fails (on the Netduino 3 and confirm that the WiFi is connected w/network before starting server).
I've tried different ports, different controller endpoints and on a specially isolated wifi network I use for testing.  One thing I noticed is that there are two exceptions before the server spins up.
Here is the output:
A first chance exception of type 'System.NotSupportedException' occurred in Microsoft.SPOT.IO.dll
A first chance exception of type 'System.IO.IOException' occurred in Microsoft.SPOT.IO.dll
Interface nr: 1
Is dhcp enabled: True
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
Interface address:
Gateway address:
Physical address: 92-134-74-1-38-13
Subnet mask:
Selected interface:
Local endpoint, IP: Port: 8500
Any suggestions?
Lance McCarthy
Microsoft MVP (Windows Platform Development)
#8 Fredde
  • 8 posts
Posted 05 December 2015 - 11:37 PM
Sorry for the very very late answer, I dont have any Netduino with Wifi so I have not tested it on that hardware.
But if you have an issue please file it on github so I will see it, I am not here that often now days but its really fun to see that you like it!
