Cant get an IP address
ipaddress network
#1 Terrence
Terrence
  • 24 posts
Posted 17 December 2014 - 04:03 AM
public static void WaitForIPAddress()
	byte[] MAC = { 0x5C, 0x86, 0x4A, 0x00, 0xF2, 0x15 };
	NetworkInterface ni;
	NetworkInterface.GetAllNetworkInterfaces()[0].EnableDhcp();
	NetworkInterface.GetAllNetworkInterfaces()[0].PhysicalAddress = MAC;
		ni = NetworkInterface.GetAllNetworkInterfaces()[0];
		if (ni.IPAddress != "0.0.0.0") break;
		Debug.Print("Waiting for an IP Address...");
		Thread.Sleep(1000);
I have a Netduino plus 2, running netmf 4.3.1
I can't get an ip address.  When I look at the network interface it tells me my dns ip address, but that number is actually my gateway address?  My IP address is always 0.0.0.0.
I have read other posts, and am using the suggested code.  Any help would be great.
Thanks.
Terrence
#2 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 20 December 2014 - 07:05 AM
Hi Terrence,
Trying setting the device MAC address using the MFDeploy tool so you don't have to hard code it in your app.
Here is some code I use for showing network config, connectivity status changes etc.
Bryn
blog.devmobile.co.nz
using System.Net;
using Microsoft.SPOT.Net.NetworkInformation;
      NetworkInterface networkInterface = NetworkInterface.GetAllNetworkInterfaces()[0];
      // Comment in/out as required or us MF Deploy
      networkInterface.EnableDhcp();
      networkInterface.EnableDynamicDns();
      NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
      NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
      // Display network config for debugging
      DisplayNetworkInformation();
      while (NetworkInterface.GetAllNetworkInterfaces()[0].IPAddress == IPAddress.Any.ToString())
         Thread.Sleep(1000);
   static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
      Debug.Print("NetworkChange_NetworkAvailabilityChanged " + e.IsAvailable.ToString());
   static void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
      Debug.Print("NetworkChange_NetworkAddressChanged");
   public static void DisplayNetworkInformation()
      Debug.Print("Network configuration");
      Debug.Print(" Network interface type: " + networkInterface.NetworkInterfaceType.ToString());
      Debug.Print(" MAC Address: " + BytesToHexString(networkInterface.PhysicalAddress));
      Debug.Print(" DHCP enabled: " + networkInterface.IsDhcpEnabled.ToString());
      Debug.Print(" Dynamic DNS enabled: " + networkInterface.IsDynamicDnsEnabled.ToString());
      Debug.Print(" IP Address: " + networkInterface.IPAddress);
      Debug.Print(" Subnet Mask: " + networkInterface.SubnetMask);
      Debug.Print(" Gateway: " + networkInterface.GatewayAddress);
   public static string BytesToHexString(byte[] bytes)
      string hexString = string.Empty;
      // Create a character array for hexidecimal conversion.
      const string hexChars = "0123456789ABCDEF";
      // Loop through the bytes.
      for (byte b = 0; b < bytes.Length; b++)
         if (b > 0)
            hexString += "-";
         // Grab the top 4 bits and append the hex equivalent to the return string.
         hexString += hexChars[bytes[b] >> 4];
         // Mask off the upper 4 bits to get the rest of it.
         hexString += hexChars[bytes[b] & 0x0F];
      return hexString;
  • mregen likes this
#3 Spiked
Spiked
  • 129 posts
Posted 20 December 2014 - 04:32 PM
I'd agree on using the hardware mac address first.
But if that is something you can not do, try setting it before you ask for a dhcp address.  Otherwisee mac '1234' ask for an IP address, then changed itself to '5678'  - it will never receive a reply.
#4 Terrence
Terrence
  • 24 posts
Posted 21 December 2014 - 11:28 AM
Thanks guys for the reply.  Turns out setting the MAC address before did the trick.
Terrence
Also tagged with one or more of these keywords: ipaddress, network
