VBA Questions About Events and Analogs
#1 STGMavrick
STGMavrick
Posted 08 December 2014 - 03:40 PM
I've got some questions that are stumping me. I purchased a Netduino Plus 2 a while ago and never really tinkered with it until I decided to do some light controls for the Christmas tree. I'm a PLC programmer by day and it's driving me nuts that what I want to do I would already have done in ladder logic in a matter of minutes. But I'm persistent and determined to learn this thing so here we go.
I'm trying to use a single pushbutton to turn lights on and off.  I used the eventhandler example posted on the boards here but I kept running into debouncing issues with the button and I did not know how to add a duration of button press so I switched to two buttons.
Imports Microsoft.SPOT
Imports SecretLabs.NETMF.Hardware.Netduino
Module Module1
    Dim ButtonState As Boolean = True
    Dim led As New OutputPort(Pins.GPIO_PIN_D1, False)
    Dim Potentiometer As AnalogInput = New AnalogInput(Cpu.AnalogChannel.ANALOG_0)
    Dim ScaledValue As Double = 0
    Sub Main()
        Dim ButtonOff As InterruptPort = New InterruptPort(Pins.GPIO_PIN_D0, False, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow)
        AddHandler ButtonOff.OnInterrupt, AddressOf ButtonChangeHigh
        ButtonOff.EnableInterrupt()
        Dim ButtonOn As InterruptPort = New InterruptPort(Pins.GPIO_PIN_D2, False, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow)
        AddHandler ButtonOn.OnInterrupt, AddressOf ButtonChangeLow
        ButtonOn.EnableInterrupt()
        While ButtonState = True
            Potentiometer.Scale = 1000
            ScaledValue = Potentiometer.Read()
            led.Write(True)
            Thread.Sleep(ScaledValue)
            led.Write(False)
        End While
        Do
            Thread.Sleep(Timeout.Infinite)
        Loop
    End Sub
    Sub ButtonChangeHigh(data1 As UInteger, data2 As UInteger, time As Date)
        ButtonState = True
    End Sub
    Sub ButtonChangeLow(data1 As UInteger, data2 As UInteger, time As Date)
        ButtonState = False
    End Sub
End Module
So, What I'm seeing is that If I declare buttonstate as true initially I can turn it off.  However, I cannot turn it on again. I'm assuming I am not doing it correctly. Ideally though I would prefer a single pushbutton to toggle the system on and off.
Secondly, My Analog input declaration would not work with my code I have written unless I used CPU.AnalogChannel.AnalogChannel_0. Pins.GPIO_PIN_A0 would complain about implicit conversion.
Thirdly, do these have RTC abilities? I originally wanted to have two modes. Manual on/off and time controlled. Start at X hour, stop at y hour.
I appreciate your help!
Posted 06 August 2015 - 04:33 AM
Hi STGMavrick,
I was just looking through older posts and noticed that you hadn't received any responses to this. Let me see if I can help get you pointed in the right direction.
For debouncing: I recommend just checking the current time. Go ahead and react to the pushbutton--but keep a timer value which stores the "last pushed" time in ms...and if it has been less than 10ms since the last push...ignore the new event. No need for two buttons.
[Also...you may want to use EdgeBoth instead of EdgeLow for your interrupt trigger, so that you can see when the button is released.]
Ah, good observation. The Pins enumeration only works for digital inputs/outputs. Do you have access to the AnalogChannels.ANALOG_PIN_A0, etc. enumeration?
No RTC, but you can do this pretty easily in code. Just subtract the current DateTime from the target DateTime and then set a timer to wake up your logic. There's no battery backup and you do need to set the time after boot--but this should work well.
BTW, welcome to the Netduino community!
#3 Enrique Gil-Leyva Flores
Posted 28 November 2016 - 12:36 AM
Hi STGMavrik
this is happening because you have not imported the SecretLabs.NETMF.Hardware.Analog refence
Best Regards,
Enrique
