Problem getting I2C to start
1 reply to this topic
#1 Pablo020
Pablo020
  • 5 posts
Posted 06 December 2014 - 01:34 AM
Hello folks,
I have a ND+2, VS2103, Latest firmware etc..
I run the following code snippet:
using System.Net;
using System.Net.Sockets;
namespace BasicMaster
        private static I2CDevice.Configuration _i2cDeviceConfiguration = null;
        private static I2CDevice _i2cDevice;
            Debug.Print("Main started");
            _i2cDeviceConfiguration = new I2CDevice.Configuration(0x00, 400);
            _i2cDevice = new I2CDevice(_i2cDeviceConfiguration);
            for (int i = 0; i < 100000; i++)
                SendOnlyI2cMessage(i);
                Thread.Sleep(50);
        private static void SendOnlyI2cMessage(Int32 counter)
            I2CDevice.I2CTransaction[] transactions = new I2CDevice.I2CTransaction[1];
            byte[] RegisterNum = new byte[1] { 2 };
            transactions[0] = I2CDevice.CreateWriteTransaction(RegisterNum);
            Int32 executeResult = _i2cDevice.Execute(transactions, 1000);
            if (executeResult == 0)
                Debug.Print("I2C transaction, Counter = " + counter.ToString() + ", ExecuteResult = Failed (value = 0)");
            else
                Debug.Print("I2C transaction, Counter = " + counter.ToString() + ", ExecuteResult = " + executeResult.ToString());
I connected the SD and SC pins via 10K resistors to the +3.3V.
A scope is connected to both the clock and the data (SC and SD pins).
Scenario 1:
- build app
- deploy and debug app
- app starts and code is running, as I see the debug print stuff coming in.
Result:
I see both channels on the scope indicating a flat 3.3V... but no signs of any signal generated by the netduino. (See first attachment)
Strange ... I expected the execute to fail, however, I ought to see some 'proof' of attempts on the signals.
Then ...
- I disconnect 3.3V pin, and reconnect ....
Result:
I see the expected signal. See second attachment.
The same effect I get in the following scenario:
Scenario 2:
- above code is running. I did the 3.3V disconnect - reconnect routine. And i can see the signal.
- I press the reset button of the ND+2
- After restart, again I see the image 1... a flat 3.3V
- Disconnect 3.3V and Reconnect 3.3V
- Result: image 2, a clear signal!
Am I doing something wrong?
Can I fix this from the software?
Any feedback would be appreciated!!
Paul
#2 dino4net
dino4net
  • 40 posts
Posted 08 December 2014 - 04:02 PM
There was a workaround some time ago I still use in my I2C projects.
Put it at the beginning of the project to give the port the right level. Also advice to get a Scanna Plus device from ikalogic.com to debug this type of problems in minutes.
            //Workaround for a bug where you need to disconnect the I2C bevore it works.
            OutputPort p = new OutputPort(Pins.GPIO_PIN_SDA, true);
            p.Write(false);
            p.Dispose();
