Playing around with a Neopixel library I wrote
Fading
https://onedrive.liv...E84D56B35!15115
Pulse fade
https://onedrive.liv...E84D56B35!15118
Will post code when I add a couple more functions
1 reply to this topic
Posted 24 November 2014 - 11:40 PM Playing around with a Neopixel library I wrote
Fading https://onedrive.liv...E84D56B35!15115
Pulse fade https://onedrive.liv...E84D56B35!15118
Will post code when I add a couple more functions Netduino Plus 2
Posted 28 November 2014 - 09:25 PM Here's the class I made. After reading a lot about these Neopixels I decided to get a Neopixel stick. Thanks to Jcoders post and a lot of others I was able to write one myself. Im by far not a programmer just a hobby so code might not be the most efficient or professional but I tried. Imports System Imports Microsoft.SPOT Imports System.Text Public Class Pixel ' Gets the string reprsentation on an 24bit rgb color. For 1 Neopixel led Red = 8 bit Green = 8 Bit Blue = 8 bit Function color(ByVal green As Integer, ByVal red As Integer, ByVal blue As Integer) As String Dim R As String = Convert2Bin(red) Dim G As String = Convert2Bin(green) Dim B As String = Convert2Bin(blue) red = CInt(R) green = CInt(G) blue = CInt(B) Dim binaryred = (red.ToString("D8")) Dim binarygreen = (green.ToString("D8")) Dim binaryblue = (blue.ToString("D8")) ' Return a 24 bit string in the GBR order needed for the neopixel Dim Led24bitcolor = binarygreen & binaryred & binaryblue Return Led24bitcolor End Function ' Same as above but used for more that 1 pixel ''' Obsolete uses alot of memory can crash when led count > 60 ''' ' Use SendAllLedData(color,x) instead of Color(string,x). In theroy can handle 400+ led YMMV (Ps** Will "light up 3000 leds" :):D no effects and stuff like that though :( try to keep it lower) Function color(ByVal green As Integer, ByVal red As Integer, ByVal blue As Integer, ByVal leds As Integer) As String Dim R As String = Convert2Bin(red) Dim G As String = Convert2Bin(green) Dim B As String = Convert2Bin(blue) red = CInt(R) green = CInt(G) blue = CInt(B) Dim binaryred = (red.ToString("D8")) Dim binarygreen = (green.ToString("D8")) Dim binaryblue = (blue.ToString("D8")) Dim Led24bitcolor = binarygreen & binaryred & binaryblue 'Repeats the string by any given amount Dim allLed24bitcolor As String = New StringBuilder().Insert(0, Led24bitcolor, leds).ToString Return allLed24bitcolor End Function ' Converts integer number representing a byte (0-255) to string in a binary format (00000000 to 11111111) Function Convert2Bin(ByVal LedValue As Integer) As String Dim sb As New System.Text.StringBuilder While LedValue <> 0 sb.Insert(0, (LedValue Mod 2).ToString, 1) LedValue \= 2 End While Return sb.ToString() End Function 'Phases the string to a byte array. Neopixels require a centain timing logic for data. Using SPI the netduino is able to meet the demand. Shared Function SendAllLedData(ByVal color As String, ByVal LedCount As Integer) As Byte() 'Setting up the byte array and splitting the sting in a string array so that each element can be phases into required logic 1 or 0 Dim x As Integer = 0 Dim bitcolor As String() = New String(color.Length - 1) {} Dim b2sa As Byte() = New Byte(bitcolor.Length - 1) {} Dim LedsData() As Byte = Nothing Dim y, z As Integer For i As Integer = 0 To color.Length - 1 bitcolor(i) = color(i).ToString() Next ' Phases each element in the string array and replaces 0 with 128 and 1 with 252 then dumps each elemnet into a byte array in the same order it came in For i As Integer = 0 To bitcolor.Length - 1 Dim data As String = bitcolor(i) Select Case data Case "0" bitcolor(i) = "128" Case "1" bitcolor(i) = "252" End Select Next For i As Integer = 0 To bitcolor.Length - 1 b2sa(i) = Byte.Parse(bitcolor(i)) Next ' Used if controlling more than 1 pixel y = (24 * LedCount) - 1 z = 0 ReDim LedsData(y) While z <= y Array.Copy(b2sa, 0, LedsData, z, 24) z += 24 End While Return LedsData End Function End Class Here is how to use it Imports Microsoft.SPOT Imports Microsoft.SPOT.Hardware Imports SecretLabs.NETMF.Hardware Imports SecretLabs.NETMF.Hardware.Netduino Imports NetduinoApplication10.Pixel Module Module1 Sub Main() Dim NeopixelConfig As SPI.Configuration Dim NeopixelSpi As SPI NeopixelConfig = New SPI.Configuration(Pins.GPIO_PIN_D10, False, 0, 0, False, True, 6666, SPI.SPI_module.SPI1) NeopixelSpi = New SPI(NeopixelConfig) ' Neopixels require a reset time of 9us to 40 us inbetween new data packets this just send 0 bytes lasting about 16 us. Still have to integrate into a funtion Dim Reset As Byte() = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0} Dim Pixel As New Pixel ' Seting us the colot data Dim White = Pixel.color(255, 255, 255) ' Preping the color data to be sent as one big array. Note - Using loops during spi.wirte causes a delay breaking the timing needed for the neopixels ' 8 is for the amount of leds I will be using (Neopixel stick) Dim data = SendAllLedData(White, 8) 'Send all data NeopixelSpi.Write(data) NeopixelSpi.Write(Reset) End Sub End Module Still writing a bit of functions such as (shifting led colors, animation, and fading) for it will be added soon If you have any algorithms or functions you'd like to share psot or pm Netduino Plus 2 Also tagged with one or more of these keywords: netduino, neopixels, spi
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | |||||||||||||||||||||||||||
