Hi
I'm trying to build the netduino firmware with the gcc4.4 compiler. I have installed the Sourcery G++ with the gcc4.4 and the MircoFrameworkPK 4.1. I've copy jeremy's port for the gcc4.4 over the netduino firmware in the MF folder.
Then I call the setenv_gcc4.4.cmd c:\gcc and after the msbuild Solutions\Netduino\dotnetmf.proj /t:build /p:flavor=release > out.txt
The run failed with some reasons. Sadly, I dont know and I can't figure out what is the reason. I have the build out put attached.
out.txt 176.22KB
9 downloads
I know a large file, but I hope somebody has an idea.
Thanks a lot.
Josch
Question for firmware build with gcc4.4
Started by Joschua, Jan 20 2011 07:10 PM
Posted 20 January 2011 - 07:10 PM
Posted 21 January 2011 - 08:39 AM
It's a linking that fails: arm-none-eabi-ld.exe
Try do the linking manually. It might tell you some more then.
Also add a -v or -verbose flag.
Posted 21 January 2011 - 12:22 PM
Hi Illishar
Thanks for your answer. I'm currently using gcc 4.2 and it works. I will spend more time later to figure out my issue.
Regards
Josch
