Hi all, i'm newbie with netduino and trying to make it communicate with my laptop throught RS232 port.
I've bought this shields http://www.cutedigi....oducts_id=4329.
and tried to use some code i've found on this forum int post
http://forums.netdui...n-help-please/.
Then i conneted netduino to my pc using a standard RS232 cable.
Result :
NOTHING ! seems taht netduino doesn't receive any data from pc.
Pls i really need it.
RS232 COMMUNICATION PROBLEM
Started by RandallFlagg, Jan 20 2011 12:51 PM
Posted 20 January 2011 - 12:51 PM
Posted 20 January 2011 - 06:10 PM
Hi Randall,
Are the "TX" and/or "RX" LEDs on the shield flashing?
Posted 21 January 2011 - 07:06 AM
Hi Randall,
yes when i try to communicate txd led is flashing green.
But the software method ondatareceive doesn't trigger.
Posted 21 January 2011 - 07:15 AM
Randall,
Have you tried updating to the v4.1.1 alpha 5 firmware? We fixed all known .NET MF serial port bugs with the latest firmware.
Also, when you send data from your computer the RXD led on the shield should flash, not the TXD led. If the TXD led is flashing when you send data from your computer, you have the wires swapped. Try using an RS232 cross-over cable or adapter to swap the TX and RX lines. [A regular straight-through male to female cable should be wired properly to start with though.]
Posted 21 January 2011 - 02:41 PM
SOLVED!!! the rs232 cable has to be NORMAL and not cross. The shield cross the signal!
Thank's all
