Using NETMF SerialPort in NET 4.5 Application
SerialPort NET 4.5
#1 salvadorrichter
salvadorrichter
  • 7 posts
  • LocationSouth Germany
Posted 07 September 2014 - 07:47 PM
I wrote a library in NETMF using the library in a Netduino application and in a .NET 4.5 Windows Desktop application.
It worked out fine for several cases until I added the Class SerialPort
The Definition in Microsoft.SPOT.Hardware.SerialPort.dll and in System.dll is incompatible.
VS Forces me to add Microsoft.SPOT.Hardware.SerialPort.dll to references when  I add my NETMF library, but then it complains for ambiguos Definition with System.dll.
Any way out this Dilemma?
I dont want to implement same function twice.
Regards
Salvador
#2 Spiked
Spiked
  • 129 posts
Posted 07 September 2014 - 08:04 PM
keep the serial port out of the common code or
surround it with #if MF_FRAMEWORK_VERSION_V4_3 #else
I thought serial port would be in System.IO?
In any case, writing common code for a serial port between two different hosts may be pushing it, but I guess it could be done. I have mixed feelings on the utility of this. I would tend to write more robust code where resources are not constrained (error handling, longer messages, bigger buffers), but I have no idea as to your reasons to not want to do that.
#3 salvadorrichter
salvadorrichter
  • 7 posts
Posted 08 September 2014 - 07:23 PM
Yes, the SerialPort is in the package System.IO
I would like to use bidirectional communication between netduino and a Windows application, so I'd like to use the same code on both sides.
I think about isolating the Code for the SerialPOrt and implemet this part twice.
