Graphical LCD
Posted 20 January 2011 - 08:24 AM
I hope I can use without some sophisticated intermediate electronics?
Miha.
Posted 20 January 2011 - 02:35 PM
Posted 20 January 2011 - 05:10 PM
I bought this Graphic LCD 128x64 STN and I'm now wondering how to use it with Netduino. Where do I start (besides the datasheet)?
Miha.
just looking at the application notes from that website, it would appear that this site has some good information to start with and use for testing the LCD. I also found this on Sparkfun. It has some c code that you would need to port but it gives you a place to start.
http://jarrodsinclair.wordpress.com//
Posted 20 January 2011 - 05:59 PM
Posted 20 January 2011 - 07:07 PM
Posted 20 January 2011 - 07:09 PM
Thanks for the pointers guys. I'll take a look. BTW, how does a "driver" look like? Is it just a class which encapsulates the logic for communication with specific component or is it something else?
Exactly. Drivers are C# code wrapped in a class, containing all the logic and communication necessary to interface with a component. Some might call them "component classes."
Posted 13 February 2011 - 08:16 PM
The instructions in the "readme" of this KS0108 driver say:
put the OpenLabs.NETMF.Hardware.LCD folder in the DeviceCode\Interop\ folder put the OpenLabs.NETMF.Hardware.LCD.featureproj Framework\Features\ folder then add the OpenLabs.NETMF.Hardware.LCD feature to the netduino solution via the Solution Wizard. recompile firmware and download. Run the demo application to see a simple starfield on your display.
This all seems pretty straightforward, but I don't even know where to find this DeviceCode\Interop.
I don't know what it means to recompile the firmware with this code, as I've never done it before (are there some step-by-step instructions somewhere)? I suppose I would need a source firmware for this to work?
So, I decided to just create a managed wrapper, replicating functionality in the native and managed code of the driver.
Of course it does not work
Basics first:
- Connecting 3rd pin (V0 - Operating voltage for the LCD (variable)): I connected it to the 5V, same as pin 1 on the LCD (Vdd - Supply voltage)). The manual says that Vdd-V0 should be typically 9.5V, so I guess V0 should be more like -5V than 5V? How can I get -5V on a ND+?
- I didn't even connect VEE (Operating voltage for LCD (variable)) - what does it do?
And then, there is my software, which is drawing some pixels (or, it is supposed to be
Is there a way I could test that the LCD is working somehow? (maybe if would know how to recompile firmware and download to device, that would be a good start)
I saw that characters can be written to the display as well, but I found no instructions as to what to write to LCD to make it work (well, even pixels don't work for me at the moment). Anybody knows?
Thank you for any pointers,
Miha.
Posted 13 February 2011 - 11:50 PM
Posted 14 February 2011 - 06:41 AM
If you head over to the Downloads page, you can download the .NET MF source and the Netduino source (which is where you'll find the files mentioned in that README file). Then you can use the free GCC compiler to build it. If you search for gcc in the search box, you should find the compiler instructions that community members have put together.
Thanks Chris. I'll give it a shot. I suppose I can return back to the 'default' firmware later on without issues.
Miha
Posted 28 February 2011 - 08:32 AM
Posted 28 February 2011 - 10:56 AM
Posted 28 February 2011 - 11:11 AM
If you're just starting out and you don't have a prebuilt native driver for your display, it's definitely easier to start out with an LCD display (or a simple graphical display that you can control from native code).
so which one do you suggest? The one I have is
I've spent so much time on this LCD already I might as well buy a new one, but I'd like to know which one, so that I don't spend money for nothing. (Edit: this would probably fit the bill nicely)
Of course, I'd be most interested in making the one I have work, but since there are no simple troubleshooting procedures to check whether some parts of it are working or not, I guess I'm stuck. I might as well start and try to port some Arduino code for it -- only I suspect I will fail again, since the drivers and sample app I compiled don't work with it anyway.
Miha.
Posted 28 February 2011 - 12:04 PM
Posted 24 July 2011 - 10:10 AM
If that's a terrible recommendation, let me know what you're looking for (characters vs graphical, frequent vs. occassional refereshes, fast vs. slow) and I'll take a look at them and make a few recommendations...
Hey Chris!
Been busy with my work for a "while" now
I looked at project showcase where there are excellent libraries, but I don't know (did I miss that somehow??) for which LCDs are they.
Would something like [1] work with library showcased in [2]?
[1]:http://www.skpang.co.uk/catalog/serial-enabled-16x2-lcd-white-on-black-33v-p-921.html (I'm from EU, so buying from EU distributors makes more sense)
[2]:http://forums.netduino.com/index.php?/topic/756-serial-graphic-display-from-sparkfun-set-of-classes/
Miha.
Posted 24 July 2011 - 05:41 PM
I'd recommend starting out with one of the displays which already has a sample project going for it.
Either in the Wiki (see this Nokia screen for example) or on the Forums.
I'd recommend Serial or SPI for simplicity--or I2C if it has pull-up resistors already included on it.
Posted 24 July 2011 - 07:23 PM
Thanks Chris! The raw communication method is killing me. I'm porting some AVR code to try and work with this thing, but I'm about to give up on it. Also, it used most of my pins, and I need to connect a clock, a temp sensor and a few buttons to it... So serial or SPI really seems like a best alternative. I'll see what EU dealers have with regards to Nokia screen.
Thanks again!
Miha
