Maximum port frequency ...
Best Answer mikepo, 28 August 2014 - 05:17 PM
I think we can safely exclude 100MHz and 2GHz, but you probably already knew that :)
500kHz looks pretty unlikely too ...
Does this help (towards the end of the post, under: "Bit toggling"):
http://informatix.mi...s/MeepMeep.aspx
It's not talking about Netduino in particular but the .Net Micro Framwork in general. But some good insights ...
"So basically, with a 100 MHz processor, you can usually do around 20 ?s wide pulses using managed code (about 25 kHz)."
Another similar discussion on the TinyCLR forum:
https://www.ghielect...?id=4052&page=1
"72 MHz sounds very fast.
But I was surprised that outputting an alternating 0 and 1 via .NET code was so slow!
I got only 10 kHz."
So I am guessing it would be less than 10kHz, if your code runs on the Netduino Go and communicates the command to toggle a pin to the shield base over the go!bus protocol ...
5 replies to this topic
#1 DaveFer
DaveFer
  • 21 posts
  • LocationAustin, TX
Posted 27 August 2014 - 08:52 PM
Hi all. I apologize in advance if this topic has already been exhausted. I DID search prior to posting but I'm pressed for time.
What is the maximum frequency at which I can toggle a port on the Shield Base?
Please note:  This isn't a PWM quesiton. I'm not asking the minimum period or duty cycle or anything related to PWM.
The question is simply looking for the highest frequency that a port can be toggled steadily (turned on and off / high and low). 500 KHz? 100 MHz? 2GHz?
Thank you. Again, sorry if this has already been discussed and exhausted.
- Dave Ferreira
#2 theTroll
theTroll
  • 54 posts
Posted 27 August 2014 - 09:42 PM
A lot of that depends on what else you are doing.  If all you are doing is fliping the port, you can do it a lot quicker than if you have a lot of other stuff going on.  So it is not something that can really be answered because no one can know your code.
#3 DaveFer
DaveFer
  • 21 posts
Posted 28 August 2014 - 04:04 AM
Sure. Of course it's unanswerable if there are other processes taking up cycles. Thanks.
I'd like to get a ballpark idea of the maximum frequency I can toggle the port with NOTHING else going on. A theoretical limit if nothing else.
#4 mikepo
mikepo
  • 29 posts
Posted 28 August 2014 - 05:17 PM   Best Answer
I got only 10 kHz."
#5 DaveFer
DaveFer
  • 21 posts
Posted 29 August 2014 - 04:23 AM
Thanks, Mike. Yeah, that's the info I needed.
So, I'm not going to be able to create any kind of radio signal by toggling a port on the Netduino ... at least not in the amateur bands (2 meter band). That would require about 145 MHz.
I would have to create some dedicated tank circuit and then perhaps manipulate it using the Netduino. :)
   - DF
#6 CW2
Posted 29 August 2014 - 01:21 PM
You should have mentioned that in the original post - Shield Base has STM32F205 microcontroller that runs at 120 MHz, Netduino Go STM32F4 at 168 MHz. So, not enough for 145 MHz pin toggling even when done in assembly...
