Netduino Plus 1 and Pins class - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
14 replies to this topic
#1 BlueSky
BlueSky
  • 13 posts
Posted 14 August 2014 - 06:26 AM
Hi, I have a question! In Pins class some variables of Cpu.Pin are created and integer values have been assigned to them. In the usual, it is not possible because Cpu.Pin is an enum and we can’t assign new integer values to them. How is this possible?
For example:
public const Cpu.Pin ONBOARD_LED = 55;
I’m using the Netduino Plus 1 and Firmware v4.1.
Posted 14 August 2014 - 02:56 PM
Hi BlueSky,
Try type-casting the pin #...
Cpu.Pin ONBOARD_LED = (Cpu.Pin)55;
Does that get you going?
#3 BlueSky
BlueSky
  • 13 posts
Posted 14 August 2014 - 07:38 PM
I know for this casting, I can use these ways:
1)
public const Cpu.Pin ONBOARD_LED = (Cpu.Pin) 55;
2)
public const Cpu.Pin GPIO_PIN_D2 = (Cpu.Pin) 0;
public const Cpu.Pin ONBOARD_LED = GPIO_PIN_D2 + 55;
3)
implicit operator
But this casting in the Pins class was interesting for me and I like to understand how it is possible because there is not any casting in this code!
Thanks for your help.
I would like to know about programming the Pins class in SecretLabs.NETMF.Hardware.NetduinoPlus namespace!
#4 beastyboy
beastyboy
  • 194 posts
  • LocationNetherlands
Posted 15 August 2014 - 04:18 PM
default type for enum is int:
check this:
http://msdn.microsof...y/sbbt4032.aspx
But changing them is considered bad practice:
http://msdn.microsof...y/cc138362.aspx
Cheers Olaf
Van SchOten Ict Diensten en Services
http://www.voids.nl
#5 BlueSky
BlueSky
  • 13 posts
Posted 15 August 2014 - 08:00 PM
Hi Cheers,
Thanks for your help! These links in accordance with my statement. You also agree with me, right?
I know default type for enum is int.
But we can assign integer values to each enumerator when we define an enum.
When we define a variable of enum, we are not allow to assign new integer value to it, because it is a compiler error!
In this sample after defining an enum (Cpu.Pin) ,an integer value have been assigned to a variable of Cpu.Pin!
I’ve tested this code and it is a compiler error!
and in this link:
it is said:
To assign an arbitrary value to a variable of an enumeration type is to introduce a high risk for errors.
#6 beastyboy
beastyboy
  • 194 posts
Posted 16 August 2014 - 01:06 AM
The danger is that you should not change enum values and just set them once.
For example the cpu.pin ONBOARD_LED could have a different value on the Netduino 1 and the Netduino Plus.
So only use the names and don't change the values.
They are to be set by the actual person that knows how the pins relate.
So if they are set to 55 then that is the correct value for your hardware.
They should be set only one time and not to be changed during execution.
So the variable is attached to the ONBOARD_LED not to the cpu.pin that is just the type.
http://www.voids.nl
#7 BlueSky
BlueSky
  • 13 posts
Posted 16 August 2014 - 06:16 PM
Thanks for your help, Cheers! But I’m confused!
I know about setting of pins and their values, but my question about programming these and their assignments!
For the first time, When Pins class is written and is run successfully (without error)?
You mean that the setting is done at the time of porting board? This mean that there is an error but this program is running correctly in the first (at the time of porting)? If I want to write a Pins class with correct values, I don’t have any problems and it is running successfully? So how do you solve compiler error?
Because I really have an error for this line! :(
Error :
Cannot implicitly convert type 'int' to 'Microsoft.SPOT.Hardware.Cpu.Pin'. An explicit conversion exists (are you missing a cast?)
afsane
#8 BlueSky
BlueSky
  • 13 posts
Posted 18 August 2014 - 05:22 PM
Hi everyone,
There is no one to help me?! :huh:
#9 Chris Walker
Posted 18 August 2014 - 06:16 PM
Hi BlueSky,
If you use the explicit type conversion [i.e. (Cpu.Pin)55] then it should work for you. Due to the way that Cpu.Pin is defined and used, we recommend using explicit conversions if you need to specify a physical MCU pin #.
#10 CW2
Posted 18 August 2014 - 07:01 PM
Where exactly do you see this code? I cannot find it anywhere in the source. Are you inspecting the assembly (.dll) with some tool like .NET Reflector?
#11 BlueSky
BlueSky
  • 13 posts
Posted 18 August 2014 - 08:07 PM
Hi chris,
Thanks alot for your help! :)
#12 BlueSky
BlueSky
  • 13 posts
Posted 18 August 2014 - 08:13 PM
Hi CW2,
No, I don’t use any software.
In the visual studio, you should write Pins and then right click on Pins and after that, click on Go To Difinition!
So you can see Pins class in a new tab, and you can see this code!
I attach the picture of it for you!
namespace test1
            Pins
#13 Spiked
Spiked
  • 129 posts
Posted 18 August 2014 - 08:38 PM
You have to watch how names of pins get passed around.
I define a variable like such
RegulatedMotor M0 = new RegulatedMotor( PWMChannels.PWM_PIN_D5, Pins.GPIO_PIN_D9, Pins.GPIO_PIN_D10 );
but the function is defined
public RegulatedMotor(Cpu.PWMChannel pwmPin, Cpu.Pin encA, Cpu.Pin encB) { ... }
#14 CW2
Posted 18 August 2014 - 08:44 PM
Ok, thanks for the information. Well, the explanation is the code you see is not the actual source, but generated by Visual Studio via reflection - and obviously it is not quite correct, as the [mandatory] cast is missing. It could even be a 'feature', to make the definition easier to read by removing the obvious cast.
#15 BlueSky
BlueSky
  • 13 posts
Posted 19 August 2014 - 04:17 AM
Oooo…! :o
I didn’t know this! Excuse me for my mistake!
CW2, you’ve really helped me! Thanks for your help.
And everyone, Thanks a lot for your help,too! :)
