Trying to recreate Arduino Code for Netduino, running into issues.
UDP Netduino Plus 2
#1 berr08
berr08
  • 9 posts
Posted 05 August 2014 - 07:41 PM
Basically trying to setup my base functionality that I have used in all my arduino setups.
I listen for a UDP message, then store the IP of the sender to send data back...idea is the application sends a GO commands over UDP the sensors start blaring and send json back to the application.
My issue iss the my socket.RemoteEndPoint is always saying the IPAddress is 0.0.0.0, so now I don't know where to send these messages to.
I'm using an example that I found on here for sending a receiving messages, it might be more than I need but just trying to get this working then remove the overkill.  So with the example below the listener.RemoteEndPoint is always saying 0.0.0.0 for the IP address.  Please help, just to better explain what I am doing I will put the arduino code below as well.
Thanks everyone, loving the netduino so far happy to get away from c/c++ mashup of the arduino!!!
#region The actual worker thread code
        /// <summary>
        /// This is a method which does the work of the worker thread.
        /// It is a bit like the program's main() function (but is not static).
        /// It waits (sleeps) for a UDP message to be received and passes it using the
        /// supplied Interface.
        /// </summary>
        private void Main()
            int bytes = 0;              // Holds number of bytes received
            var rxBuff = new byte[100]; // Holds received message
            // Convert IP address and port to an EndPoint
            IPEndPoint localEndPoint = new IPEndPoint(localIpAddress, port);
            // Create a "UDP" socket.
            Socket listener = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            // Bind the socket to the local endpoint and listen for incoming UDP datagrams.
            try
                listener.Bind(localEndPoint);
            #region Catch exceptions
            catch (SocketException se)
                SocketErrorCodes errorCode = (SocketErrorCodes)se.ErrorCode;
                switch (errorCode)
                    case SocketErrorCodes.NetworkIsDown:
                        Debug.Print("Socket Exception on creation: NetworkIsDown");
                        break;
                    default:
                        Debug.Print("Socket Exception error: " + errorCode);
                        break;
            #endregion
            // TODO: If the network was down set up a timer to try again in a while.
            // Now that we have bound the socket to liste on the port, set a timeout for receive operations
            // We could just wait for ever, but having a timeout may be useful.
            listener.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReceiveTimeout, 1000);
            // Loop forever
                bytes = 0;
                string cause = "unknown";
                // TODO: Currently we assume that one whole message will be received in one go
                // This may not be the case - consider using a length for the first byte and just
                // read the length at first, followed by the correct amount of following bytes.
                // Without doing this we might receive less than a whole message or even
                // parts of two messages.
                try
                    //Debug.Print("Attempt to listen on " + localEndPoint.ToString());
                    bytes = listener.Receive(rxBuff);
                #region catch exceptions
                    switch (errorCode)
                            // The network is not connected.
                            cause = "NetworkIsDown";
                            //Debug.Print("Socket Exception on receive: NetworkIsDown");
                            // Ignore error and carry on
                            break;
                        case SocketErrorCodes.ConnectionTimedOut:
                            // Connection timed out - e.g. nothing received
                            cause = "ConnectionTimedOut";
                            //Debug.Print("Socket Exception on receive: ConnectionTimedOut");
                            break;
                        default:
                            break;
                #endregion
                if (bytes == 0)
                    // Nothing may have been received if a timeout or an error occured.
                    Debug.Print("Nothing received: reason - " + cause);
                else
                    // Create a copy of the message that is the correct length
                    var msg = new byte[bytes];
                    for (int i = 0; i < bytes; i++)
                        msg[i] = rxBuff[i];
                    // Use interface to pass message to main thread
                    IPEndPoint ip = listener.RemoteEndPoint as IPEndPoint;
                    receiver.SetRemoteIP(ip.Address);
                    receiver.MsgRx(msg);
        #endregion
void receiveData()
  remoteAddress = udp.remoteIP();            // Store IP as Remote IP
  udp.read(packetBuffer,5);                  // Read the packet into buffer
  // **For Testing Only**
  Serial.println(F("Contents:"));
  Serial.println(packetBuffer);
  // **Process Messages**
  if (strcmp(packetBuffer,"GOGO") == 0)
      receivedStart = true;
  else if (strcmp(packetBuffer,"STOP") == 0)
      receivedStart = false;
#2 berr08
berr08
  • 9 posts
Posted 06 August 2014 - 03:34 PM
I've had more time with this, so I started pulling the code apart making it simplier to understand (for the way I think atleast).  Starting with the receiving part, have the code done, but I'm having 2 issues.
  1. The RemoteEndPoint IP is still always 0.0.0.0, I need to figure out the IP that is sending the message so I can send the results back to that same IP.
  2. I have it working to read 1 message, but then everything craps out and even though it says there are 4 bytes available to read (once I send another message) the 'bytes = listener.Receive(rxBuff);' always return 0 and leaves the byte array empty.  Am I missing a step?
If anyone can help at all it would be much appreciated, hopefully I'm just missing a step somewhere?
Program.cs
using System.Net;
using System.Net.Sockets;
using System.IO;
using Microsoft.SPOT.Net.NetworkInformation;
namespace UDPMag_NetduinoPlus2
        private static IPAddress myIPAddress = null;
        private static int dataPort = 8888;
        private static UDPReceiver udpReceiver = null;
            //Make Sure Network is setup.
            SetupTCPIPFromSD();
            //Setup Listener to handle incoming Commands, this runs a listener thread.
            udpReceiver = new UDPReceiver(new IPEndPoint(myIPAddress, dataPort));
            udpReceiver.OnMessageReceived += new UDPReceiver.MessageReceived(udpReceiver_OnMessageReceived);
            //The sender event is going to be created when we get our first message in the OnMessageReceived Handler.
            //Keep the thread alive as we are using all listeners and events.
        static void udpReceiver_OnMessageReceived(string message, IPEndPoint sender)
            Debug.Print(sender.Address.ToString() + ": " + message);
        private static void SetupTCPIPFromSD()
            NetworkInterface ethernet1 = NetworkInterface.GetAllNetworkInterfaces()[0];
            if (ethernet1.IPAddress == "192.168.5.100")
                //Setup Defaults as SD Card is not working currently...
                string LocalIPAddress = "10.201.1.99";
                string SubNetMask = "255.255.255.0";
                string Gateway = "10.201.1.254";
                if (File.Exists(@"IPData.txt"))
                    using (FileStream filestream = new FileStream(@"IPData.txt", FileMode.Open))
                        StreamReader reader = new StreamReader(filestream);
                        Debug.Print(reader.ReadToEnd());
                        reader.Close();
                ethernet1.EnableStaticIP(LocalIPAddress, SubNetMask, Gateway);
            myIPAddress = IPAddress.Parse(ethernet1.IPAddress);
UDPReceiver.cs [Class]
using System.Net;
using EthernetSocketDefs;
    public class UDPReceiver
        public delegate void MessageReceived(string message, IPEndPoint sender);
        public event MessageReceived OnMessageReceived = null;
        private IPEndPoint localEndPoint = null;
        private IPEndPoint remoteEndPoint = null;
        public UDPReceiver(IPEndPoint ipeo)
            this.localEndPoint = ipeo;
            // Create a delegate of type "ThreadStart", which is a pointer to the
            // worker thread's main function
            ThreadStart delegateWorkerThread = new ThreadStart(Main);
            // Next create the actual thread, passing it the delegate to the main function
            Thread threadWorker = new Thread(delegateWorkerThread);
            // Now start the thread.
            threadWorker.Start();
        /// <summary>
        /// </summary>
        private void Main()
            byte[] rxBuff = null;       // Holds received message
            try
                switch (errorCode)
                        break;
                    default:
                        break;
            listener.ReceiveTimeout = 1000;
            // Loop forever
                bytes = 0;
                try
                    if (listener.Available > 0)
                        rxBuff = new byte[listener.Available];
                    else
                        cause = "No Data Available";
                catch (Exception ge)
                    if (ge is SocketException)
                        SocketErrorCodes errorCode = (SocketErrorCodes)((SocketException)ge).ErrorCode;
                        switch (errorCode)
                                break;
                                break;
                            default:
                                break;
                    else
                        cause = ge.Message;
                if (bytes == 0)
                else
                    // set the remote end point so we know who sent us the data.
                    remoteEndPoint = listener.RemoteEndPoint as IPEndPoint;
                    //Convert to string.
                    System.Text.UTF8Encoding e = new System.Text.UTF8Encoding();
                    string txtMessage = new string(e.GetChars(rxBuff));
                    // Call Event!
                    if (OnMessageReceived != null)
                        OnMessageReceived(txtMessage, remoteEndPoint);
        private bool SocketConnected(Socket s)
            return !(s.Poll(1000, SelectMode.SelectRead) & (s.Available == 0));
        #endregion
#3 berr08
berr08
  • 9 posts
Posted 07 August 2014 - 04:59 PM
To Update I have removed the Debug.print statments and changed a bunch of different things that seemed trivial (basically banging my head on the keyboard) and it started to continue to read after the first message.  Don't know why but it did...code is below incase anyone needs it.
At this point the only issue that remains is how to get the IP of the UDP message sender.  Any one know how to get that? It's not coming back in the Socket.RemoteEndPoint, so for testing I hard coded my IP to get the messages back....Pretty please? :D
using System.Net;
        /// <summary>
        /// It waits for a UDP message to be received and passes it using the
        /// supplied Event.
        /// </summary>
        private void Main()
            try
                switch (errorCode)
                        break;
                    default:
                        break;
            listener.Listen(16);
            // Loop forever
                bytes = 0;
                rxBuff = new byte[4];
                try
                    if (listener.Available >= 4 && listener.Poll(1000, SelectMode.SelectRead))
                        bytes = listener.Receive(rxBuff, 4, SocketFlags.None);
                    else
                        switch (errorCode)
                                break;
                                break;
                            default:
                                break;
                    else
                        cause = ge.Message;
                if (bytes == 0)
                    //Debug.Print("Nothing received: reason - " + cause);
                else
                    remoteEndPoint = new IPEndPoint(IPAddress.Parse("10.201.1.24"), 8888);//listener.RemoteEndPoint as IPEndPoint;
                    // Call Event!
        #endregion
#4 jrlyman3
jrlyman3
  • 67 posts
  • LocationNorth St Paul. MN
Posted 11 August 2014 - 02:31 AM
I took a quick look and I think that you're missing:
IPEndPoint localEndPoint = new IPEndPoint(IPAddress.Any, port);
before listener.Bind(localEndPoint);
Also, you should use listener.RecieveFrom() which will receive the data and tell you who it came from.  This works best with UDP since you can receive data from multiple hosts on the same socket (no connection).
John
#5 berr08
berr08
  • 9 posts
Posted 11 August 2014 - 01:36 PM
Interesting, I will give this a shot, thanks for the feedback!
Also tagged with one or more of these keywords: UDP, Netduino Plus 2
