http://microliquidcr...l.codeplex.com/. But as I add its reference to project, something goes wrong with netduino, its led stays turned on and debugging gets auto closed. But as removed the reference, all works fine.
I tried LCD class from embedded-Lab, but it just flicks and all black boxes appear again..
What could be the problem ?
Edit: After setting framework to 4.2 of microliquidcrystal, no more netduino light stays on, but text still not appearing. I even changed the pins.
Edit 2 :
Its 20x2 LCD, specs here http://www.microelec...act/ccm2020.pdf
var lcdProvider = new GpioLcdTransferProvider( Pins.GPIO_PIN_D12, // RS Pins.GPIO_PIN_D11, // ENABLE Pins.GPIO_PIN_D5, // D4 Pins.GPIO_PIN_D4, // D5 Pins.GPIO_PIN_D3, // D6 Pins.GPIO_PIN_D2); // D7 var lcd = new Lcd(lcdProvider); lcd.Begin(20, 2); lcd.Write("Test"); Thread.Sleep(Timeout.Infinite);
