Hi
is the SKU unique and cant change programmatically or firmware update
![]() Netduino Unique ID
Started by asciiman, Jul 22 2014 03:10 AM
8 replies to this topic
Posted 22 July 2014 - 03:10 AM Hi
DeviceInfo:
HAL build info: 4.3.1.0, Netduino 2 (v4.3.1.0) by Secret Labs LLC
OEM Product codes (vendor, model, SKU): 34, 177, 4101
Serial Numbers (module, system):
00000000000000000000000000000000
0000000000000000
Solution Build Info: 4.3.1.0, Netduino 2 (v4.3.1.0) by Secret Labs LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.3.1.0
Microsoft.SPOT.Native,4.3.1.0
Microsoft.SPOT.Hardware,4.3.1.0
Microsoft.SPOT.Net,4.3.1.0
Posted 24 July 2014 - 01:49 PM What scope of uniqueness are you referring to?
The number is stored in the flash memory and the current firmware does not expose flash memory routines to user application, so in this context it cannot be changed programmatically. Technically, it is possible to customize the firmware to enable access to flash memory routines from the user application (managed code) and there are other programs that can be used to modify flash memory contents, such as MFDeploy, JTAG/SWD programmer etc.
Firmware update does not change SKU, unless you deliberately flash firmware for different SKU - e.g. it is possible to have Netduino firmware running on Netduino Plus (of course Plus-specific features do not work).
Posted 25 July 2014 - 08:25 AM hi sir
thanks for your interest.
I wanna develop commercial program and I need uniqe value on N2 or N2+.
Firstly i think, I can use MAC addres on N2+. But it can changeable with MFDeploy isnt it?
?s there unique value on N2 or N2+ or what can i do?
Posted 25 July 2014 - 12:13 PM Yes, MAC address can be changed.
The Netduino 2/Plus 2 microcontroller has unique ID feature, unfortunately it is not available in the current firmware, mostly due to privacy concerns (it has been already discussed several times on this forum). You can modify the firmware or you can use another device to store unique ID, such as EEPROM (small memory chip, interfaced from Netduino through SPI or I2C).
Posted 25 July 2014 - 01:08 PM Hi sir,
When I use EEPROM that somebody can read and write on other EEPROM isnt it? Is EEPROM has uniqueID ?
Posted 25 July 2014 - 05:48 PM Assuming that the Netduino is part of some circuit, maybe you could use a 1-wire unique serial number, http://www.maximinte...cts/DS2411.html
Posted 21 August 2014 - 03:30 AM
You can use that if you are comfortable soldering surface mount chips.
If you'd rather solder through hole components, Maxim makes a bunch of other 1-wire chips with unique serial numbers on them like the DS18B20 https://www.sparkfun.com/products/245
Posted 21 August 2014 - 06:28 AM thnx 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
