Best Answer jonlf, 01 August 2014 - 09:14 PM
Boy do I feel stupid. It was a line level issue. Thanks for the second set of eyes on something I should have known to look at more closely.
![]() ![]() Best Answer jonlf, 01 August 2014 - 09:14 PM
Boy do I feel stupid. It was a line level issue. Thanks for the second set of eyes on something I should have known to look at more closely. Go to the full post![]()
9 replies to this topic
Posted 21 July 2014 - 07:27 PM I am just getting started with an N+2 and am seeing some odd behavior when collecting serial data. Below is the code I am using to collect data on COM1. private static SerialPort _port; public static void Main() { _port = new SerialPort(SerialPorts.COM1, 9600); _port.DataReceived += new SerialDataReceivedEventHandler(DataReceived); _port.Open(); Debug.Print("Start scanning!"); Thread.Sleep(Timeout.Infinite); } private static void DataReceived(object sender, SerialDataReceivedEventArgs e) { while (_port.BytesToRead > 0) { var data = _port.ReadByte(); Debug.Print(data.ToString()); } } The serial output is coming from a PC running Putty. I have tested PC to PC and am getting the ASCII values I expect. However, when sent to the N+2 I get the following codes... Char ASCII 0 6 1 103 2 51 3 102 4 25 5 101 6 50 7 100 8 12 9 99 I tried working it out on paper to see if it was an endian issue or bit inversion but am not seeing it. Can anyone help point me in the right direction? I must be missing something very simple. Just in case I have included the dump from my Device Capabilities. I appreciate any help you guys can provide. Not Supported Not Supported Not Supported Not Supported Connecting to NetduinoPlus2_Netduino...Connected HalSystemInfo.halVersion: 4.2.0.0 HalSystemInfo.halVendorInfo: Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC HalSystemInfo.oemCode: 34 HalSystemInfo.modelCode: 177 HalSystemInfo.skuCode: 4102 HalSystemInfo.moduleSerialNumber: 00000000000000000000000000000000 HalSystemInfo.systemSerialNumber: 0000000000000000 ClrInfo.clrVersion: 4.2.0.0 ClrInfo.clrVendorInfo: Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC ClrInfo.targetFrameworkVersion: 4.2.0.0 SolutionReleaseInfo.solutionVersion: 4.2.2.2 SolutionReleaseInfo.solutionVendorInfo: Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC SoftwareVersion.BuildDate: Jan 26 2013 SoftwareVersion.CompilerVersion: 410894 FloatingPoint: True SourceLevelDebugging: True ThreadCreateEx: True LCD.Width: 0 LCD.Height: 0 LCD.BitsPerPixel: 0 AppDomains: True ExceptionFilters: True IncrementalDeployment: True SoftReboot: False Profiling: False ProfilingAllocations: False ProfilingCalls: False IsUnknown: False
Posted 22 July 2014 - 04:35 PM N/m putty. Baud mismatch maybe?
Isn't there some concern using com1 while the debugger is running? I thought you had to jump through hoops to get it to work at all, so I've always just used ethernet.
Posted 23 July 2014 - 01:12 PM Baud rate or setting mismatch was my first thought. I have verified 9600, 8, none, 1. I was not aware of com1 issues while debugging so ran another test without the debugger attached. I have even tried running on com2 without good results. A colleague is also doing some dev and is seeing the same issue with his device. These are new devices we just received within the last week.
Posted 23 July 2014 - 01:32 PM What cable do you use to connect Netduino Plus 2 to the PC? Could it be faulty (e.g. cheap USB converter)?
Posted 23 July 2014 - 01:38 PM I am connecting the RS232 port (5V) from my PC using pins 2,3 and 5 to the appropriate pins of the UART on the netduino. There is no converter cable being used. Regarding the table, the first column represents the character I sent to the netduino, the second column represent the char code (ASCII) the netduino "sees" or spits back. I have since modified the code to echo back the character it receives and I get improperly translated characters as I would expect based on the table provided.
Posted 23 July 2014 - 01:48 PM Are you sure the RS232 port on your PC is 5V? Usually, they are standard ±12V; and "5V" RS232 can also mean ±5V (and not 0 - 5V). Netduino has 3.3V logic (inputs in digital mode are 5V tolerant), so you'd need a level converter to connect it to PC.
Posted 23 July 2014 - 02:40 PM If it also fails on com2, it almost certainly would be an electrical problem to me, as CW2 suggests. I suspect many of us do not even have PC's with RS-232 serial ports any longer, I know I do not.
Since you and your friend both have Netduinos, a netduino to netduino test might shed some light.
Posted 23 July 2014 - 07:44 PM RS232 uses inverted logic; TX/RX idle logic low. Netduino COM ports idle high. Most PC serial ports are RS232 and they may or may not conform to the RS232 standard (+/- 12V). Measure the TX voltage on your PC serial port. If it is less than about 2.5V, then your problem is inverted logic. You can invert TX/RX with a 74LVC2G14 or a 74HC14 Schmitt trigger Inverter The simplest thing to do is just buy a USB to serial TTL adapter and forget the PC serial port.
Posted 27 July 2014 - 03:12 AM You need an rs232 shield. You can't directly plug into the serial port due to voltages or some such. I tried something similar, and went through the same pain of not understanding why. Fortunately, the shield is only $12, so it's not a killer. And you don't have to change any code at all.
I would paste a url to the shield, but this forum software won't let copy and paste work in Internet Explorer. I've posted about this before but nothing has been done to fix it. Just search for cutedigi rs232 shield for arduino. Either v1 or v2 will work for you.
Hope this helps.
Posted 01 August 2014 - 09:14 PM Best Answer Boy do I feel stupid. It was a line level issue. Thanks for the second set of eyes on something I should have known to look at more closely. Also tagged with one or more of these keywords: UART
1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | |||||||||||||||||||||||||||
