Reading Multi Byte from Serial Port
serialport
Best Answer asciiman, 22 July 2014 - 03:43 AM
hi
I wrote this
/// <summary>
/// Start of Text Transmission (STX) character
/// <para>Hexadecimal: 0x02 ~ Decimal: 2</para>
/// </summary>
public const char STX = '\u0002';
/// <summary>
/// End of Transmission Block (ETB) character
/// <para>Hexadecimal: 0x17 ~ Decimal: 23</para>
/// </summary>
public const char ETB = '\u0017';
private static System.Collections.ArrayList _SerialInBuffer;
	_SerialInBuffer = new System.Collections.ArrayList();
	var xSerialPort = new System.IO.Ports.SerialPort("COM1", 9600, System.IO.Ports.Parity.None, 8, System.IO.Ports.StopBits.One);
	xSerialPort.Open();
	xSerialPort.DataReceived += xSerialPort_DataReceived;
private static void xSerialPort_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
	var xSerialPort = sender as System.IO.Ports.SerialPort;
	byte[] xReceivedBytes = new byte[xSerialPort.BytesToRead];
	xSerialPort.Read(xReceivedBytes, 0, xReceivedBytes.Length);
	foreach (byte xReceivedByte in xReceivedBytes)
		if (xReceivedByte == STX)
			_SerialInBuffer.Clear();
			_SerialInBuffer.Add(xReceivedByte);
		else if (xReceivedByte != ETB)
		else    // ETB
			byte[] tmpBytes = new byte[_SerialInBuffer.Count];
			_SerialInBuffer.CopyTo(tmpBytes);
			string xSerialCommand = new string(System.Text.Encoding.UTF8.GetChars(tmpBytes)) + ETB;
			string xValue = xSerialCommand.Trim(new char[] { STX, ETB });
			Microsoft.SPOT.Debug.Print(xSerialCommand);
and you must send data like this
string xTransmittingData = STX + "this data will be send" + ETB
#1 Senthil
Senthil
  • 5 posts
Posted 20 July 2014 - 11:20 PM
 I am trying to read a value from COM1 using DataReceived Event. But with below sample I was able to ready only Single Byte ,  What I wanted to do is to read String . Say "On" "Off" I do I do it ?
        static SerialPort port;
            port = new SerialPort("COM1", 9600, Parity.None, 8, StopBits.One );
            port.Open();
            port.DataReceived += new SerialDataReceivedEventHandler(port_DataReceived);
        static void port_DataReceived(object sender, SerialDataReceivedEventArgs e)
            byte[] byte1 = new byte[1];
            port.Read(byte1, 0, byte1.Length);
char[] c = System.Text.Encoding.UTF8.GetChars(byte1);
            String a = new String(c);
            if (a == "n")
              //on led
            else if (a == "f")
               //off led
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 21 July 2014 - 05:15 PM
Generally I find that you have little control over the way the data is presented.  So you may send a 20 byte string to the Netduino from say a PC but you my get that in chunks.  In the past I have captured all of the data being sent over the serial line in a buffer and looked out for a special "end of line" marker, say carriage return.  When the marker is received I process all of the data from the start of the buffer to the marker.
If you want some example code then you can have a look at what I did connecting a PC to a Netduino using a Bluetooth serial port.
Hope this helps,
#3 asciiman
asciiman
  • 56 posts
  • LocationTurkey
Posted 22 July 2014 - 03:43 AM   Best Answer
hi
I wrote this
/// <summary>
/// </summary>
/// <summary>
/// </summary>
	xSerialPort.Open();
		else    // ETB
