I have just unpacked and tried to use a Netduino Go! starter kit I bought a while back.
I would like to use it with my 11-year old grandson who is already OK with LEGO Mindstorms EV3 and using the LabVIEW graphic style programming for it.
I am an old guy who is not an expert either in hardware nor in C# but I am pretty experience with using Windows applications. I bought Netduino Go! because I wanted to get started without soldering!
I was somewhat disappointed not to be able to find a single file which would allow me to set up and test the Go! and the 4 modules supplied.
I have a copy of the Getting Started With Netduino book by Chris Walker.
I followed the instructions on the website to install the 3 software packages.
Checking the details from My Downloads these are
1. MS Visual C# Express 2010 (as expected)
2. MS .NET Micro Framework v 4.2 SDK dated 13/08/2012 (not v4.1 as stated)
3. Netduino SDK v4.2.2 dated Jan 2013 (not v4.1 as stated)
I entered and ran the Blinky program as per instructions - which compiled and installed but just left the power light on - so I had no idea why it wasn't working. So I replaced the infinite loop with a counted loop so it would terminate:
using SecretLabs.NETMF.Hardware.NetduinoGo;
namespace NetduinoGoApplication1
OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);// write your code here
Int64 count = 0;
while (count < 20)
led.Write(true); //turn on the LED
Thread.Sleep(250); //sleep for 250ms
led.Write(false); //turn off the LED
count = 1 + count;
But stil no joy. So I searched the Forum and found that the Go! seems, as others have said, to be rather the Cinderella of the Netduino family. Then I found that the blue LEDs are not yet flashable, but the white power LED is. So I replaced the first line with:
OutputPort led = new OutputPort(Pins.PowerLed, false);
and now have my first successful program running - so I know the kit works. Now I need a simple explanation of just what additional code is needed to use each of the modules in the starter kit - but I can't find it.
So could someone please post the code needed to:
(a) wait until the Button is pressed on Ch 1
turn on a LED attached to the shield base on Ch 5 (and tell me which 2 pins I should I use)
© wait until the Button is pressed again on Ch 1 and then
(d) loop allowing me to use the Potentiometer attached to Ch 3 to control the colour and/or brightness of the RGB LED attached to Ch 4
(e) until the Button is pressed again on Ch 1.
I would be most grateful!
