NP2 SD IO strange problem, bug ??
SD CardNP2 read error bug?
#1 kerk-akker
kerk-akker
  • 12 posts
  • LocationNetherlands
Posted 29 April 2014 - 12:59 PM
I am using the SD card to store settings for my climate control program. During testing I sometimes get a System.IndexOutOfRangeExemption in System.IO.dll. It seems the program can not read the next line and generates and exemption.
After a lot of testing it seems that this error depends on the data that I write. For example if my file contains lines with test data: 0,3,1,0,222,22.12 I get the above error. If I take out the "." and store 0,3,1,0,222,2212 I do not get the error. In this example the behavior is consistent, a few debug runs give the same result. So, depending on the contents of the lines in the file it crashes or not ??
The error happens somewhere during the reading; i.e. a large number of lines are read correctly and then suddenly the above error appears.
I am not an experienced programmer so maybe I am doing something wrong.
I am quite desperate as this data logging is fundamental for my project........
Please help,
Arno
#2 knut.tveitane
knut.tveitane
  • 18 posts
Posted 29 April 2014 - 01:31 PM
Hi Arno,
Difficult to tell without seeing the code where the exception happens. Are you trying to read your numbers as integers?(The value 22.12 is not an int but a real... 2212 however is int)
-knut
#3 kerk-akker
kerk-akker
  • 12 posts
Posted 29 April 2014 - 01:48 PM
Hi Knut,
Thanks for fast response. I am reading the data as text and later convert to int or float. I have attached the code below.
Looking forward to your feedback,
Br,
Arno
#4 kerk-akker
kerk-akker
  • 12 posts
Posted 29 April 2014 - 06:30 PM
I have made a workaround, I read the file from SD at once with r.ReadToEnd() and then I split the file in lines and extract the data from each line. This is working. If I use r.ReadLine() I still get strange errors like described in my previous post. I suspect something with the StreamReader buffers as in some traces I have seen that I get a problem when the reading is crossing the bufferlevel. I mean when a line is e.g. from position 500 to 525 and the buffer is set on 512. I have tried to increase the buffer in StreamReader but in the traces I could not see that it changed. It stayed on 512 bytes.
I am still open for any tips what I might have done wrong and why I can not use s.ReadLine() to read my datafile on the SD.
I have attached the updated code.
Arno
