1-Wire DS18B20 Programming Errors
#1 escallanio
escallanio
  • 9 posts
  • LocationSydney
Posted 29 April 2014 - 12:49 PM
I am work on constrained protocol having NetDuino platform (v4.2.2). I added OneWireBus.cs and DS18B20.CS to my server for temperature monitoring of the room. However, i am getting errors
Error1:
'Observe_Server_Netduino.Program' does not contain a definition for '_oneWire' and no extension method '_oneWire' accepting a first argument of type 'Observe_Server_Netduino.Program' could be found (are you missing a using directive or an assembly reference?) E:\CoAP Implementation\Observing Resources\Observe-Server-Netduino\Observe-Server-Netduino\Program.cs 169 26 Observe-Server-Netduino
 Error 2:
The type or namespace name 'DS18B20' could not be found (are you missing a using directive or an assembly reference?) E:\CoAP Implementation\Observing Resources\Observe-Server-Netduino\Observe-Server-Netduino\Program.cs 170 17 Observe-Server-Netduino
I am using drivers from
Funny thing is they work perfectly fine as standalone. but when i integrate them into my server program, i am getting the above errors. Any Idea?
escallanio
#2 escallanio
escallanio
  • 9 posts
  • LocationSydney
Posted 29 April 2014 - 01:06 PM
Ah,
Been able to solve the first error (Error 1). I was missing
private OneWire _oneWire = null;
However, still i am getting error 2. :(
#3 kerk-akker
kerk-akker
  • 12 posts
  • LocationNetherlands
Posted 29 April 2014 - 01:09 PM
I am doing also temp monitoring with DS18B20. It works fine. It seems you are missing a "using statement" or a Reference entry. I only discovered with long wires ( about 20 metres ) I can only add two sensors on one port. As such I have defined multiple ports as one wire bus. I am currently running 7 sensors on 4 GPIO's. Working fine.
Br,
Arno
#4 SomeGuy
SomeGuy
  • 10 posts
Posted 21 March 2015 - 01:20 PM
hi!
I just got started with this temp thing & I got some errors too ...
I'm using  the same sensor with a NetduinoPlus 1 & the v4.2 of the firmeware ...
I've found this post in which the guy explains how to wire the sensor and he has put a simple example of code that he has used base on the same classes you've mentioned (Mr. escallanio ) , the OneWireBus.cs & the DS18B20.cs
this's the post : http://bradsduino.bl...support-my.html .
I did exactly the  same thing but i get this error at the OneWireBus (at the " var devs = ow.FindAllDevices();" line)
public enum Family : byte
            Unknown = 0x00,
            DS18S20 = 0x10,
            DS18B20 = 0x28,
        public static Device[] Scan(OneWire ow, params Family[] includeFamilies)
            var list = new ArrayList();
            var all  = false;
            if( includeFamilies != null )
                foreach( var f in includeFamilies )
                    if( f == Family.Unknown )
                        all = true;
C# throws an exception and highlight the line above
some help please!!
#5 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 25 March 2015 - 08:30 AM
Hi SomeGuy,
I used the bradsduino code as the basis for the sample below which I use for testing my sensors
using ThreelnDotOrg.NETMF.Hardware;
public class TemperatureDS18B20Demo
      public static DS18B20 outletTemperature;
         Timer outletTimer;
         outletTemperature = new DS18B20(Pins.GPIO_PIN_D2);
         outletTimer = new Timer(timerCallbackExhaustTemperature, null, 5000, 30000);
      static void timerCallbackExhaustTemperature(object state)
         try
            float temperature = outletTemperature.ConvertAndReadTemperature();
            Debug.Print("Temperature " + temperature.ToString("F2"));
         catch (Exception ex)
            Debug.Print("ERROR: failed with error: " + ex.Message);
I find that if I use D1 (shared with serial port) it doesn't work.  I use Seeedstudio plug-n-play Grove Kit so this maybe a feature of my hardware
http://www.seeedstud...sor-p-1235.html
http://www.seeedstud...-V2-p-1378.html
What is the exception you are getting?
B: blog.devmobile.co.nz
T: @KiwiBryn?
