Protection!
Posted 16 August 2010 - 02:01 PM
Posted 16 August 2010 - 06:40 PM
Posted 16 August 2010 - 07:57 PM
Anything meant for the Arduino will work for the Netduino (except for the USB and power connectors, of course)
http://www.esawdust....und-arduinousb/ << Those guys make pretty good stuff. Like I said, you'll still need a plate for the side connectors.
bah those look boring I'll make my own out of Plexiglas
Posted 16 August 2010 - 08:24 PM
Here is another enclosure from Adafruit
http://www.adafruit....products_id=271
I just ordered one so I can tell you shortly how netduino fits inside.
Posted 16 August 2010 - 08:49 PM
that one is a little better. I'd rather have a clear one.
Posted 16 August 2010 - 08:52 PM
Posted 16 August 2010 - 09:04 PM
It won't be as thick as a plexiglass one or the ones linked, but you could ramp up the process to work with thicker materials. Plus this comes in handy for making custom pieces for projects.
Posted 16 August 2010 - 09:10 PM
Posted 16 August 2010 - 10:01 PM
I like thisOr you can make your own vacuum former!
Posted 17 August 2010 - 12:19 AM
Dude thanks! I made one using a bowl (nice big surface area!) the top of a Fanta bottle and sealed it with hot glue and that white tape stuff used on pipes. Its sweet! thanks again
Posted 17 August 2010 - 06:44 AM
OZ, it sounds like you'll have a very nice looking case whatever you do!
Szymon, Chris Seto--thanks for the links to the cases. Maybe we should ask one of the manufacturers to make a Netduino-specific case?
I think that in general you would choose the case that fits best for your project, considering all additional components that you might be using.
That said I think adafruit's case looks quite robust and can fit quite a lot. For larger or more ruged projects Chameleon case might work better http://www.esawdust....cl-cham1-basic/
For both enclosures we just need a proper faceplate to expose the netduino ports (or just a template to cut them ourselves from blank faceplate).
Here are few more examples:
http://blog.makezine..._enclosure.html
http://blog.makezine...duino_case.html
http://www.thingiverse.com/thing:1664
Posted 17 August 2010 - 03:21 PM
Posted 17 August 2010 - 05:00 PM
I like the stackable one a lot, that way you can keep building.
Thanks to all for posting these.
Posted 23 August 2010 - 02:08 PM
Posted 23 August 2010 - 06:40 PM
Here you can see few photos of it: http://cid-4c7ec0c21...e.aspx/Netduino
That looks really good. Too bad the USB is offset a little, but thats an easy fix. You could even seal up the old hole. Good luck with that LCD screen!
Posted 09 February 2013 - 09:04 AM
OZ, it sounds like you'll have a very nice looking case whatever you do! Szymon, Chris Seto--thanks for the links to the cases. Maybe we should ask one of the manufacturers to make a Netduino-specific case? Chris
Seems it is a forgotten issue. I have conversations with Hammond but they ask for detailed cad files ...do you have anything?
