Socket
#1 Stari
Stari
  • 26 posts
Posted 14 February 2014 - 04:59 PM
i have a small automation program, that comunicate with WiFly. Ok, if WiFly is connected, if not, my program hangs.Connection i make with timer. as i say, all things work perfectly, if WiFly is ON. If not, program "hangs" without any message.
Thank you
#2 jrlyman3
jrlyman3
  • 67 posts
  • LocationNorth St Paul. MN
Posted 16 February 2014 - 03:54 PM
It seems like this should be easier ...
In C# I would set Socket.Blocking = false (which causes the Connect to throw an exception that I ignore), then call Socket.Poll to wait for the connect to finish, and then check if the socket is connected.
The following link shows a VB example that's not quite what you're looking for, but might get you headed in the right direction :).
  http://msdn.microsof...#code-snippet-2
Hope that this helps - John
#3 Stari
Stari
  • 26 posts
Posted 16 February 2014 - 06:23 PM
jrlyman3, thank you. Yes, this is the right direction. I'm not programmer, so i will need more time to finish.
#4 JoopC
JoopC
  • 148 posts
Posted 17 February 2014 - 09:27 AM
You program it wrong, you'll have to do it like this as example:
Const cnstHostThingSpeak As String = "thingspeak.com"
Dim IPEndPoint As New IPEndPoint(Dns.GetHostEntry(cnstHostThingSpeak).AddressList(0), 80)
Dim Host As Socket = New Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp)
Host.SetSocketOption(SocketOptionLevel.Tcp, SocketOptionName.NoDelay, True)
sending.......
Host.SendTo( Encoding.UTF8.GetBytes("blabla"), IPEndPoint)
reading:......................
Host.Poll(500000, SelectMode.SelectRead)
Dim bBytes As Byte() = New Byte(Host.Available - 1) {}
If Host.Receive(bBytes) > 0 Then
   Debug.Print(New String(Encoding.UTF8.GetChars(bBytes)))
End If
If you have a lot to read, you'll have to loop like this:
Dim strRequest as string = ""
Do While Host.Poll(50000, SelectMode.SelectRead)
        strRequest &= New String(Encoding.UTF8.GetChars(bBytes))
    Else
         Exit Do
    End If
   Thread.Sleep(200)
Loop
Debug.Print(strRequest)
#5 Stari
Stari
  • 26 posts
Posted 17 February 2014 - 05:53 PM
JoopC, thank you. Very usefull. I have make my program like this, found on Internet : http://netmftoolbox....ailable classes
OK, now things ar working.
