XML Data
Best Answer seascan, 19 January 2014 - 06:45 PM
Solved!
I added a header:
Send(client, "HTTP/1.0 200 OK" & vbCr & vbLf & "Content-Type: text/xml; charset=utf-8" & vbCr & vbLf & "Content-Length: " & Mystring.Length.ToString() & vbCr & vbLf & vbCr & vbLf)
1 reply to this topic
#1 seascan
seascan
  • 88 posts
Posted 19 January 2014 - 03:18 PM
Are there any .Net experts in the audience?
I have a webserver running on a ND+1.  It works great.  I'm sending back a small bit of XML for testing.  When I load up the webpage in IE or chrome it looks perfect.  However, when I try to read this XML from a ASP.Net page I get "Additional information: The underlying connection was closed: The connection was closed unexpectedly."
Here's my huge ASP.Net webpage (i trimmed everything down to just the line throwing the error):
Imports System.XmlImports System.Net.SocketsPublic Class GetData    Inherits System.Web.UI.Page    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load        Dim xmlDoc = XDocument.Load(MyIpAddress)    End SubEnd Class
Here's my code for returning the XML:
 Private Sub Send(client As Socket, response As String)        client.Send(Encoding.UTF8.GetBytes(response), response.Length, SocketFlags.None)    End Sub    Private Sub SendXML(client As Socket)        Dim Mystring As String = ""        Mystring = "<?xml version=" & Convert.ToChar(34) & "1.0" & Convert.ToChar(34) & " encoding=" & Convert.ToChar(34) & "UTF-8" & Convert.ToChar(34) & "?>"        Mystring += "<DataTable>"        Mystring += "<Data>"        Mystring += "<Temp1_C>28.0</Temp1_C>"        Mystring += "</Data>"        Mystring += "</DataTable>"        Send(client, Mystring)End Sub
I have added this to my asp.net web.config:
  <system.net>    <settings>      <httpWebRequest useUnsafeHeaderParsing="true" />    </settings>  </system.net>
Any thoughts?  Thanks!
#2 seascan
seascan
  • 88 posts
Posted 19 January 2014 - 06:45 PM   Best Answer
Solved!
I added a header:
