Azure Service Bus Connection
Service Bus
18 replies to this topic
#1 MGrontzki
MGrontzki
  • 3 posts
Posted 09 January 2014 - 11:18 AM
Hello netduino Forum,
I'm new here and I'm playing with my Netduino 2 plus since a few days.
My Problem:
How can I connect my netduino board to my Windows Azure Service Bus Queue, to send an receive BrokeredMessages from my other Clients.
In Standard .Net4.0 I use the Azure SDK and a NuGet-Package, so it is very easy.
If I can't use this in MF, I must code all by hand, and here is the problem.
Perhaps sombody else have some sample code to help me a little bit.
#2 Cuno
Cuno
  • 144 posts
  • LocationZrich / Switzerland
Posted 09 January 2014 - 03:24 PM
This would require SSL support, which is not available for the smaller NETMF boards like Netduino (NETMF supports OpenSSL, but this is about an order of magnitude too large for single-chip microcontrollers).
#3 MGrontzki
MGrontzki
  • 3 posts
Posted 11 January 2014 - 03:56 PM
I think it must be possible with the netduino plus 2.
I found some samples, but no helping source code, which I could understand.
#4 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 13 January 2014 - 08:06 AM
Developing a client for service bus on .Net Micro Framework is one of my future project.
If you want to develop it, you need to use HTTP REST Api interface of Service Bus. The documentation is here :
http://msdn.microsof...e/hh780717.aspx
Paolo.
Paolo Patierno
Azure Advisor
Twitter : @ppatierno
Linkedin : paolopatierno
Blog : DevExperience
Blog : Embedded101
#5 Cuno
Cuno
  • 144 posts
Posted 13 January 2014 - 04:50 PM
Yes, the REST API is the way to go; WCF and AMQP currently seem less realistic for a small device.
Do you know of a way to use the Service Bus REST API without HTTPS (except using some intermediate server as a relay)?
#6 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 13 January 2014 - 04:53 PM
The best solution could be using MQTT client on Netduino like my M2Mqtt library (http://m2mqtt.codeplex.com) but for now Service Bus doesn't support MQTT. I hope it will support MQTT very soon ! :-)
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
#7 Cuno
Cuno
  • 144 posts
Posted 14 January 2014 - 07:11 AM
Hi Paolo
Do you have any indication about MQTT becoming supported for ServiceBus? At the moment they seem to focus pretty much on AMQP.
Cuno
#8 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 14 January 2014 - 07:56 AM
Hi Cuno,
no I haven't any news....I hope that they will support MQTT protocol. AMQP is too heavy for .Net Micro Framework.
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
#9 MGrontzki
MGrontzki
  • 3 posts
Posted 16 January 2014 - 05:10 PM
Hi Paolo,
this could be the way, if AMQP is to heavy for the netduino.
It looks easy with the REST API, but not so easy for me.
If anybody have a few lines of example code for me, that I could start in the right way, that would be great!
Marco
#10 Chad Kittel
Chad Kittel
  • 4 posts
  • LocationBeaver Dam, WI
Posted 30 April 2014 - 11:27 PM
I did a Netduino -> Azure Service Bus project, but due to the lack of SSL I ended up proxying the connection with a WebAPI that I spun up on Azure Web Sites.  So, unfortunately I was stuck doing message-level encryption for the trip to the web service.  Once the web service picked it up, it then async added the message to Service Bus.  Worked out nice, just needed that broker/proxy service to work as the middleman.
Wasn't thrilled about message-level encryption, really would love to see /some/ minimal SSL support on the Netduino at some point.  At least enough for basic client interactions (maybe even with a reduced version support, ie TLS only)
#11 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 01 May 2014 - 06:16 AM
Hi Chad,
You are right....we need SSL for communication in the IoT world from Netduino. All the protocols use it for encryption (MQTT, AMQP,...).
Good exercise to connect Netduino to Web API but you haven't connected Netduino to Service Bus because you can't due to lack on SSL. However, good work !
Paolo Patierno
Azure Advisor
Blog : Embedded101
#12 Cuno
Cuno
  • 144 posts
Posted 01 May 2014 - 07:46 PM
I'd like to see a good (i.e., not OpenSSL) and light-weight (i.e., not OpenSSL) open source TLS implementation for NETMF boards like the Netduino as well. Maybe a future revision of TLS will allow for lighter-weight algorithms, as Google proposed here:
https://tools.ietf.o...ha20poly1305-01
Since our latest Mountaineer firmware release, we support the NaCl primitives, which include Poly1305. Adding ChaCha20 wouldn't be that hard. As it is, our library at least supports efficient message-level encryption, which is sometimes necessary anyway if end-to-end security is desired. Our NaCl implementation will later become open source, once the beta cycle for the firmware is over:
http://www.mountaine...crypto-library/
#13 CW2
Posted 02 May 2014 - 03:18 PM
Have you had any chance to evaluate PolarSSL or CyaSSL?
#14 Cuno
Cuno
  • 144 posts
Posted 03 May 2014 - 04:24 PM
No, unfortunately not. They seem like good candidates. PolarSSL in particular appears to have a good reputation regarding code readability, systematic testing etc. And Ive just seen that they have a FOSS license exception that mentions Apache 2.0 as a compatible license, so this would be ok for NETMF, at least for open source projects. I dont know what commercial conditions it has. Nor do I know how CyaSSL compares.
Even if code quality is good, license terms are ok both for open source and commercial projects, and footprint in terms of RAM and Flash is small, speed would remain an important question for me. I know of SSL stacks (on ARM7 cores, though) that take two minutes to open a connection...
If anyone has solid information regarding these two stacks, this would be extremely interesting. (Maybe this is premature, but Ive lost interest in MatrixSSL after reading some rather negative remarks regarding its code readability.)
#15 preconsult
preconsult
Posted 09 May 2014 - 04:01 PM
Hello
I am also working on a project where i have to put a message on a Azure Service Bus Queue. I think i am almost there. The only problem i have is that i need to get a token from Azure accesscontrol over https. I have the code working using HttpWebRequest on a normal C# code. The code is ported to microframework and compiles. But when i do the webrequest i always get a System.NotSupportedException. Is this because of the lack of SSL Support on netduino, are there any workarounds ?
If not, then it's simple not possible even with the REST Azure API to connect from netduino.
regards
Dieter
#16 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 12 May 2014 - 10:39 AM
Hi Dieter,
there isn't a workaround for it. The lack of SSL support on Netduino already blocked me to develop a Service Bus client for Netduino using HTTP REST interface.
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
#17 johnmiddleton
johnmiddleton
  • 4 posts
Posted 12 May 2014 - 10:04 PM
Well the workaround could be to write a cloud sevice webapi that receives a POST and then makes a service bus request - without SSL you would have to rely on encryping the message payload on the netduino and decrypting the payload in the Web API
#18 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 13 May 2014 - 07:17 AM
In this way you are developing a bridge but not direct connection to the Service Bus.
Of course, it is a workaround due to SSL lack but in this case I would not use an "heavy" protocol as HTTP but a more lightweight protocol like MQTT and develop an MQTT-ServiceBus bridge in the Cloud.
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
#19 compulim
compulim
Posted 21 May 2014 - 02:57 AM
A quick hack for me: an OpenWRT router in the home network and it help proxying to SSL services. There are cheap palm-sized USB-powered Wi-Fi routers that can be easily "patched" to OpenWRT, about $35-40.
