Problem with SerialPort - Netduino 2 (and Netduino 1) - Netduino Forums
#1 gomore11
gomore11
  • 87 posts
Posted 08 January 2014 - 11:12 AM
Hi. I´m having problems with my serial comunication in Netduino 2. I have the Netduino firmware 4.2.2 in the Netduino 2 and trying to develop in VS2012 with the 4.3 SDK. I can´t flash the 4.3 beta firmaware in Netduino 2 becouse it gets freezed.
The code is the next one:
public static void Main()        {            SerialPort com = new SerialPort(SecretLabs.NETMF.Hardware.Netduino.SerialPorts.COM1, 115200, Parity.None, 8, StopBits.One);            string msg="Hi";            byte[] message;            while (true)             {                Thread.Sleep(2000);                message = Encoding.UTF8.GetBytes(msg);                com.Write(message, 0, message.Length);            }
And the error it gives:
An unhandled Exception of type "System.ArgumentException" ocurred in Microsoft.SPOT.Hardware.SerialPort
I know that is a versión or assembly compatibility problema, but how can I fix it????
#2 Schildi
Schildi
  • 3 posts
Posted 11 January 2014 - 11:35 AM
I used your code and I got the same issue. My first rough guess would be to please you to open the door before trying to walk through it, that reduces headache ;)
So please try :
com.open();
before your while loop:
SerialPort com = new SerialPort(SecretLabs.NETMF.Hardware.Netduino.SerialPorts.COM1, 115200, Parity.None, 8, StopBits.One);            string msg="Hi";            byte[] message;            com.Open();            while (true)            {                Thread.Sleep(2000);                message = Encoding.UTF8.GetBytes(msg);                com.Write(message, 0, message.Length);            }
at least that helped my application still beeing alive and not throwing an exception.
Remark: I did not test if something is coming on the com port.
regards Marco
#3 gomore11
gomore11
  • 87 posts
Posted 12 January 2014 - 09:51 AM
Hi Schildi!!!
Oh my god!! how I could not realize about it!!!!!! I was trying to use the com port without openning it!!!!! Tipical dumb mistake that gets you crazy until somebody opens your eyes!!! Thank you so much!!!
