Best Answer Rik P., 03 January 2014 - 03:20 PM
Hi Rik, With NETMF, you'll want to dispose of one I2CDevice object before creating another: each I2CDevice class reserves the I2C bus. Chris
Thanks, Chris.
Rik
Support understanding I2C comms
Started by Rik P., Dec 31 2013 03:48 PM
Thanks, Chris.
Rik Go to the full post
#1Posted 31 December 2013 - 03:48 PM Hello all
I've been lucky enough to get hold of a Sparkfun 9DOF sensor stick (https://www.sparkfun.../products/10736), which uses I2C for communication. Whilst I've spent a lot of time reading up on I2C (as this is not something I have any experience with), and I'm fairly confident now with the programming model, I'm not really sure how to get started reading the sensor values from the device via I2C.
The sensor board has three onboard sensors, one of which is an ADXL345.According to the manual, this is addressed on 0x53.
Am I write in assuming I need to instantiate a new I2CDevice.Configuration object as follows? var config = new I2CDevice.Configuration(0x53,400); If that's correct, this allows me to target that device on the bus (I think). What I now need to do is 'poll' the bus on a periodic basis to retrieve the current sensor values. And this is the part I am struggling with...
The manual says the register for "X Axis Data 0" is at 0x32, and "X Axis Data 1" is at 0x33. I figured I need to create a Read transaction, but the APIs don't seem to have any parameters which target the registers I want to read from? var rxBuffer = new byte[4];var readTransaction = new I2CDevice.I2CTransaction[]{ I2CDevice.CreateReadTransaction(rxBuffer)};adxlDevice.Execute(readTransaction, 1000); With this in mind, I'm not entirely sure what I'm supposed to do in order to obtain values from the registers. My guess, is that I'm going about this completely the wrong way and would really appreciate a steer.
Any help?
Many thanks.
--- #2Posted 31 December 2013 - 06:05 PM Hi,
Reading values from I2C sensor´s memory is simple. At first, you need I2CConfiguration object. But this object is just a configuration. So, you need I2CDevice object.
Then you create an array of type I2CTransaction with two elements. As first element you use I2CWriteTransaction. You write address, from which you want to read, to the device. Second element would be I2CReadTranscation. With this transaction, you read data from selected address.
Finally, you call I2CDevice.Execute().
Hope this helps.
#3Posted 01 January 2014 - 10:21 AM Hi Stanislav,
Thank you for your reply, this has helped a lot.
I do have one follow-up query, if you don't mind. I can read from any one device at a time using the code I've written, however I cannot initialise two devices on the I2C bus, and then read from them both in sequence. When I attempt to do this, I receive an InvalidOperationException. My guess is this has to do with timing.
Any ideas?
Thanks --- #4Posted 02 January 2014 - 08:38 AM
Hi Rik,
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
