All,
Where can I get the C# class for accessing the GPS data (lat, lon, elev?) from an Adafruit Netduino GPS shield?
Milt
Posted 20 December 2013 - 04:23 PM All,
Milt
Posted 23 December 2013 - 04:48 AM Hi,
Have a look at the NetMF Toolbox GPS driver I have used it for a couple of projects
netmftoolbox.codeplex.com
Bryn
Posted 23 December 2013 - 09:41 PM Bryn,
I copied the code into a MicroFramework Microsoft C# 2010 project, see below, and it complained that namespace NmeaGps was not found. Any Ideas?
Thanks, Milt
"using System; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.Netduino; namespace NetduinoApplication1 { public class Program { public static NmeaGps Gps = new NmeaGps(); public static OutputPort Led = new OutputPort(Pins.ONBOARD_LED, false); // *********************************************************************** public static void Main() { // Binds all events to the GPS device Gps.GotFix += new NativeEventHandler(Gps_GotFix); Gps.LostFix += new NativeEventHandler(Gps_LostFix); Gps.PositionChanged += new NativeEventHandler(Gps_PositionChanged); // Starts the GPS device Debug.Print("Trying to get a fix..."); Gps.Start(); // Nice blinking LED effect when we have a fix while (true) { Led.Write(Gps.Fix); Thread.Sleep(450); Led.Write(!Gps.Fix); Thread.Sleep(50); } } // *********************************************************************** static void Gps_PositionChanged(uint Unused, uint FixType, DateTime GPSTime) { string Outp = ""; Outp += "3D-Fix: " + Gps.Fix3D.ToString(); Outp += ", Sattellites: " + Gps.Satellites.ToString(); Outp += ", Time: " + Gps.GPSTime.ToString(); Outp += ", Latitude: " + Gps.SLatitude; Outp += ", Longitude: " + Gps.SLongitude; Outp += ", Altitude: " + Gps.SAltitude; Outp += ", Knots: " + Gps.Knots.ToString() + " (" + Gps.Kmh.ToString() + " km/h)"; Debug.Print(Outp); // If you want to translate this to a Bing Maps URL, try this: Debug.Print("http://www.bing.com/maps/?q=" + Tools.RawUrlEncode(Gps.Latitude.ToString() + " " + Gps.Longitude.ToString())); } // *********************************************************************** static void Gps_GotFix(uint Unused, uint FixType, DateTime GPSTime) { Debug.Print("We got a fix, yay!!"); } // *********************************************************************** static void Gps_LostFix(uint Unused, uint FixType, DateTime GPSTime) { Debug.Print("We lost our GPS fix :("); } // *********************************************************************** } } "
Posted 24 December 2013 - 02:27 AM
Hi Milt,
The NmeaGps class in that toolbox is located inside a namespace, so you'll need a "using" statement at the top of your code so that Visual Studio knows which class you're using in your code.
Posted 25 December 2013 - 09:33 AM Specifically you'll need these two
using Toolbox.NETMF;using Toolbox.NETMF.Hardware; You'll likely also want to add to the public static NmeaGps Gps = new NmeaGps(); to add a com port and speed, something like the below public static NmeaGps Gps = new NmeaGps("COM1", 9600); Also be aware, the first power up of a GPS can take a LONG time to start returning data (5 mins is common) and unless it has a battery on it it will take that amount of time every time it's powered up. If it does have a battery, and has been powered up recently it should be much faster 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
