Best Answer jrlyman3, 30 December 2013 - 04:35 AM
I got the Host USB shield from Sparkfun. I hooked it up to an Arduino UNO (after installing the appropriate libraries, and adding a wire to the shield as described in the documentation) and it worked great with my generic barcode reader. I then started to look at the Arduino code in preparation for porting it to the Netduino. I decided that it was going to be quite a bit of work to port, and I put it on the back burner.
If you just want to support the scanner you don't have as much to port ... but, you have to figure out how it all works to know what you need and what you don't.
I suggest that you buy an Arduino and hook it up to the Netduino with a serial port. It's a way to start, and who knows maybe someone will get around to porting the USB host library to C# in 2014 :-).
John
