Newb fails to combine PUT and GET code samples from Gsiot book - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
1 reply to this topic
#1 gyre
gyre
Posted 03 December 2013 - 02:12 AM
Hi all,
I'm working through Cuno Pfister's book Getting Started with the Internet of Things.  The sample codes in the book all work for me.  So I decided to try to combine Example 11-1 (VoltageMonitor) and Example 12-1 (LedController): I wanted to write a program that would use different RequestRoutings via Yaler to both show me the current voltage of a potentiometer AND to allow me to turn the onboard LED on and off. Basically I inserted chunks of Example 11-1 into Example 12-1, made sure all references are intact, etc.  It compiles and deploys fine, and switching the LED on and off (the PUT request) works when I access try.yaler.net/my-domain/led/target.html, but reading the voltage (the GET request) yields only a blank page when I access try.yaler.net/my-domain/voltage/actual.html.
Any ideas?  I've pasted my code below (with Yaler credentials X'd out).  Any help greatly appreciated.  I'm very new to programming (2/10 at C#, 0/10 at JavaScript) so probably just making a simple mistake.
Thanks!!
using Gsiot.Server; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware.NetduinoPlus; public class LedControllerHtml {   public static void Main()   {   var ledActuator = new DigitalActuator   {   OutputPin = Pins.ONBOARD_LED   };   var lowPort = new OutputPort(Pins.GPIO_PIN_A0, false);         var highPort = new OutputPort(Pins.GPIO_PIN_A2, true);         var voltageSensor = new AnalogSensor         {             InputPin = Pins.GPIO_PIN_A1,             MinValue = 0.0,             MaxValue = 3.3         };   var webServer = new HttpServer     {   RelayDomain = "XXXXXXXX",   RelaySecretKey = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",   RequestRouting =   {   {   "PUT /led/target",   new ManipulatedVariable   {   FromHttpRequest =   CSharpRepresentation.TryDeserializeBool,   ToActuator = ledActuator.HandlePut   }.HandleRequest   },   {   "GET /led/target.html",   HandleLedTargetHtml   },   {                     "GET /voltage/actual.html",                     new MeasuredVariable                     {                         FromSensor = voltageSensor.HandleGet                     }.HandleRequest         }   }   };   webServer.Run();   }   static void HandleLedTargetHtml(RequestHandlerContext context)   {   string requestUri = context.BuildRequestUri("/led/target");   var script =   @"<html>   <head>   <script type=""text/javascript"">   var r;   try {   r = new XMLHttpRequest();   } catch (e) {   r = new ActiveXObject('Microsoft.XMLHTTP');   }   function put (content) {   r.open('PUT', '" + requestUri + @"');   r.setRequestHeader('Content-Type', 'text/plain');   r.send(content);   }   </script>   </head>   <body>   <p>   <input type=""button"" value=""Switch LED on""     onclick=""put('true')""/>   <input type=""button"" value=""Switch LED off""   onclick=""put('false')""/>   <input type=""button"" value=""Bah""   onclick=""put('bah')""/>   </p>   </body> </html>";   context.SetResponse(script, "text/html");   } }
#2 SeBo
SeBo
Posted 05 December 2013 - 07:37 PM
Hi gyre,
i´m new in the world of Netduino too, but for a litte project, i have to use this for controlling a power switch with a website.
For this project I use the Server from GSIOT like you.
I see in your code no html-code, which should be resonsed when the GET request "[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]"GET /voltage/actual.html" is recieved by the Netduino.[/color]
i cite a littel of my code, and i hope, you can see and it helps you to see what i mean,
First my Request handler:
static RequestRouting Routings = new RequestRouting{                    { "GET /", GetIndex },              // IP/ -> return index page            { "GET /index.*", GetIndex },       // IP/index.* -> return index page            { "GET /status.htm", GetStatus },   // IP/status.htm -> return status page            { "GET /edit.htm", GetEdit },       // IP/edit.htm -> return edit page            { "GET /links.htm", GetLinks },     // IP/links.htm -> return link page            { "GET /cprogram.htm", GetCode },   // IP/cprogram.htm -> return code of main program            { "GET /*", GetError },             // IP/* -> return error page            { "POST /edit.htm", GetEdit },      // IP/edit.htm with post data -> return edit page with modified settings            { "POST /index.*", GetIndex },      // IP/index.* with post data -> return index page with event handler            { "POST /*", GetError }             // IP/* with post data -> return error page        };            webServer.RequestRouting = Routings;
__
I use POST instate of PUT, because my Website on Netduino is only html, and the pages includes forms to send data over html.
__
If any Request is send, there will be voids to handel the events, for Index the code is:
 static void GetIndex(RequestHandlerContext context) {            try {                string[] SendSettings = context.RequestContent.Split('&'); // make a array of the post-data                foreach (string s in SendSettings) {                    switch (s.Split('=')[0]) {   // split post keyword and post value                        case "pw1": InOut.bTRIAC1 = !InOut.bTRIAC1; break; // switch a output on Netduino                        case "pw2": InOut.bTRIAC2 = !InOut.bTRIAC2; break;                        case "pw3": InOut.bTRIAC3 = !InOut.bTRIAC3; break;                        case "pw4": InOut.bTRIAC4 = !InOut.bTRIAC4; break;                        case "pw5": InOut.bTRIAC5 = !InOut.bTRIAC5; break;                        case "pw6": InOut.bTRIAC6 = !InOut.bTRIAC6; break;                        case "pw7": InOut.bTRIAC7 = !InOut.bTRIAC7; break;                        case "pw8": InOut.bTRIAC8 = !InOut.bTRIAC8; break;                    }                }            }            catch (Exception) { } // if no Post data are include like the first call of index.htm, the Exeption comes up[...] // some not nessesary code            context.SetResponse(SD_IO.ReadOut(@"htmlheader.htm") + SD_IO.ReadOut(@"htmlindex.htm") +                 sA[2] + sL[2] + returnFooter(), "text/html");  // Send HTML-Code back to Device which requestet the index page with Post or Get data.        }// and as short exampel from my code: (read just the htm-files from SD-Card and send them back to request starter.        static void GetLinks(RequestHandlerContext context) {            context.SetResponse(SD_IO.ReadOut(@"htmlheader.htm") + SD_IO.ReadOut(@"htmllinks.htm") + returnFooter(), "text/html");        }
___________________________________________________
So, in your case, i think you must change the code of from
to
"GET /voltage/actual.html", HandleVoltageTargetHtml
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]and add a new codeblock:[/color]
   static void HandleVoltageTargetHtml(RequestHandlerContext context){	    string requestUri = context.BuildRequestUri("voltage/actual");	    var script =		    @"<html>			    <head>"Value of Voltagesensor (Sorry, i havent used it bevor, i dont now how to handel it)                  "</body>			 </html>";	    context.SetResponse(script, "text/html");    }}
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]I hope, that this is helpfull for you. [/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Greetings[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]SeBo.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Ps. I know my code will not be the best, but for me it works fine :)[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]If you like, i can try to upload my code when you have future questions.[/color]
