Best Answer Chris Walker, 24 November 2013 - 06:41 PM
Hi Stijn, A few diagnostics steps for you... Is your Netduino Plus 2 connected directly to your router? What happens if you Debug.Print your IP address on the Netduino Plus 2? Does it match the router?
Debug.Print("ipaddress: " + Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].IPAddress.ToString());What happens if you give it a static IP address instead of using DHCP? Finally...if you run the SocketClient sample on your Netduino Plus 2 (be sure to set its Proxy setting in code to ""), does it connect to the Internet and download a webpage? Welcome to the Netduino community, Chris Go to the full post
