Hello, Im working on some app using Netduino plus. But I have a problem, whenever I try to connect any wire under voltage to any Analog Pin, Im getting "An unhandled exception of Type "System.Exception" occured in Microsoft.SPOT.Hardware.dll". Even if AnalogInput is not mentioned in the code. Could you help me with this? Thanks. René.
Netduino Plus AnalogInput error.
Started by desup, Nov 16 2013 07:23 PM
Analog Input Plus Netduino AnalogInput Pin
1 reply to this topic
Posted 16 November 2013 - 07:23 PM
Posted 16 November 2013 - 07:36 PM
Hi desup,
Connecting a wire to one of the analog inputs (which are digital + analog) won't throw an exception in your code. If the voltage was too high of a voltage for the board you could damage something, but the exception is most likely coming from something else and is probably code-related.
Can you provide a small code snippet (<= 10 lines) which exhibits the issue, along with a description of the steps to reproduce the issue? I recommend starting out with a new "Netduino Plus 2 Application".
We'll be happy to assist.
Also tagged with one or more of these keywords: Analog, Input, Plus, Netduino, AnalogInput, Pin
General →
General Discussion →
Netduino for my first productStarted by vishnusmoke, 12 Nov 2015 ![]() |
Hardware →
Netduino 3 →
ND3 hangs calling File.Delete()Started by ukkiwisurfer, 06 Nov 2015 ![]() |
Hardware →
Netduino Mini →
Flashing Netduino Mini with Netduino 3Started by tridy, 13 Oct 2015 ![]() |
General →
Netduino Pin GuideStarted by tridy, 11 Sep 2015 ![]() |
Hardware →
Why do I have to reboot my device to change the IP address?Started by cSharper, 31 Jul 2015 ![]() |
