hi, i have some problems with ethernet port. My device info are:
Pinging... TinyCLR
DeviceInfo:
HAL build info: 4.2.0.0, Netduino Plus 2 (v4.2.1.2) by Secret Labs LLC
OEM Product codes (vendor, model, SKU): 34, 177, 4102
Serial Numbers (module, system):
00000000000000000000000000000000
0000000000000000
Solution Build Info: 4.2.1.2, Netduino Plus 2 (v4.2.1.2) by Secret Labs LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.2.0.0
Microsoft.SPOT.Native,4.2.0.0
Microsoft.SPOT.Hardware,4.2.0.0
Microsoft.SPOT.Net,4.2.0.0
System,4.2.0.0
Microsoft.SPOT.Hardware.SerialPort,4.2.0.0
Microsoft.SPOT.IO,4.2.0.0
System.IO,4.2.0.0
Microsoft.SPOT.Hardware.PWM,4.2.0.1
Microsoft.SPOT.Hardware.Usb,4.2.0.0
SecretLabs.NETMF.Diagnostics,4.2.0.0
SecretLabs.NETMF.Hardware.Netduino,4.2.1.0
Microsoft.SPOT.Hardware.OneWire,4.2.0.0
Microsoft.SPOT.Time,4.2.0.0
NetduinoApplication1,1.0.0.0
SecretLabs.NETMF.Hardware,4.2.0.0
so, when i use MFDeploy.exe and ping netduino by usb is all (tinyCLR) ok but if i connect netduino by TCP/IP it doesn't respond
i am sure that the ip address is correct
