Hi all,
Is there any way to turn a Netduino Plus on/off?
FYI. I have a Netduino Plus which is powered by a battery. To save more energy, I sometimes need to turn off the device.
Mohammad
Switch ON/OFF
Started by mohammad, Sep 07 2012 04:41 PM
6 replies to this topic
Posted 07 September 2012 - 04:41 PM
FYI. The button I am going to use for this purpose, is the default button on the board.
Posted 07 September 2012 - 05:58 PM
Not clear. A simple switch in series to the battery isn't enough?
Posted 07 September 2012 - 07:54 PM
Thank you Mario. You are right, but the problem is that I already bought a lot of battery holders: https://www.sparkfun.../products/10512
Do you know how to include a switch in series to the battery?
Posted 07 September 2012 - 08:23 PM
Hi mohammad,
Look at the tiny Pololu Push button power switch for simple button on/off with the capability to turn off under software control,
http://www.pololu.co...log/product/751
There are endless designs for on/off power designs under software control. Here is a long discussion,
http://forums.parall...r-circuit-ideas
A good simple way is to use a LDO regulator with an on/off enable.
Baxter
Posted 08 September 2012 - 06:17 AM
The power saving of the Netduino is an old problem, and it's not easy to solve. As soon you connect the Vin supply, then you have *always* a current flowing. That current is estimated on some tens of mA, even in the worst case.
Seriously, I don't see any way to cut the supply off preserving the batteries. I guess that the only way is cutting the battery packs wire, and inserting a switch.
Another way could be having a "thru-circuit", having both a female and a male supply plug. That circuit can have a switch or something like that.
Posted 13 September 2012 - 05:22 PM
Hi Baxter and Mario,
Thanks for your useful information. I am going to apply the aforementioned solutions.
Cheers,
Mohammad
